SUGGEST FOR EXTENSION DEVELOPMENT
amrajadhyaksha
@RZ Re PAO extension
Post by amrajadhyaksha » Wed Jun 27, 2012 12:24 pm
Thanks, Rabbi, will have to try it out.
Looks a bit different from what I was looking for, but of course will try.
Thanks a lot.
Re: SUGGEST FOR EXTENSION DEVELOPMENT
Post by [RZ] » Wed Jun 27, 2012 12:27 pm
@amrajadhyaksha
just the sample looks different, but the logic is exactly the same.
all depends on how you use it (and of course on your imagination!)
maxime
Post by maxime » Thu Jun 28, 2012 8:19 pm
i suggest about all the photo exetensionm ade here to make it with the possibiltie of retrieval of the picture from a database in the server.
gforce7
Post by gforce7 » Thu Jul 12, 2012 8:13 pm
An extension similar to data viewer or dbts csv list but simpler. One that dynamically reads a delimited text file and populates a standard non-sortable table. Could be used for price/comparison matrix etc. A user would only have to make small changes to the text file to update prices, description, etc.
I have found php and javascripts that do something like this but I have no idea how to build it in to an extension. The code looks fairly simple especially to anyone who knows how to code.
I could devote time to help put it together, test etc.
amrajadhyaksha
Re: JQuery Accordion Menu
Post by amrajadhyaksha » Sat Jul 14, 2012 4:14 am
http://www.wysiwygwebbuilder.com/accordionmenu.html
http://www.wysiwygwebbuilder.com/jquery_accordion.html
While both the above are excellent, it is well known that another jquery extension cannot be used in the same page.
This severely restricts creative expression re: galleries etc as many of them use jquery.
Would it be possible to have an extension that behaves the same way, but does not use jquery?
The built in slide Menu is not an answer as in performance it keeps jumping up and down, page boundaries going for a toss. The jquery menu also looks more aesthetic.
Any help?
Post by BaconFries » Sat Jul 14, 2012 10:26 am
@amrajadhyaksha
What your saying is and isnt true you can use multiple jQuery extensions/Objects on the same page only if they all use the exact same version of jQuery ie 1.7.2 which at present is what all jQuery Objects use within WYSIWYG Web Builder. But if a jQuery extension useas lower or a different version then there will be conflicts.
The two Accordions that you have mentioned both use the same jQuery so they can be used on the same page, the only difference is that jQuery Accordion Widget - Version 1.1 belowis depreciated and is only intended to be used for backwards compatibilty with WYSIWYG Web Builder 7 if you wish a Accordion then it is recommened that you now use the inbuilt version found in WYSIWYG Web Builder 8 and higher
There is more than one jQuery menu as they all use it, so to help please be more specific by saying which one is giving you any issue!
Also the slide menu uses jQuery but I dont understand really what your issue is with it!
amrajadhyaksha
Post by amrajadhyaksha » Sat Jul 14, 2012 11:25 am
Thanks, BF.
I was not aware of the jquery 1.7.2 point that you have mentioned. That takes care of part of my problem.
My main problem was using a jquery extension with the accordion.
Yes, there can be different versions between the extension and the WWB 8.2.1's inbuilt jquery objects, so conflict is expected as per your clarification.
Hence the request for a menu that behaves like the jquery accordion but does not use jquery.
Thanks again for the prompt reply which was quite helpful.
Adendum
Post by Adendum » Sun Jul 22, 2012 5:44 pm
gforce7 wrote:An extension similar to data viewer or dbts csv list but simpler. One that dynamically reads a delimited text file and populates a standard non-sortable table. Could be used for price/comparison matrix etc. A user would only have to make small changes to the text file to update prices, description, etc.
Extension released: viewtopic.php?f=42&t=49343
Death to Internet Explorer!
Post by zinc » Mon Jul 23, 2012 7:45 am
This is sadly in Flash but if there is a JQ version, it would be RAD!!!!
http://bit.ly/5PrFqt
Post by zinc » Mon Jul 23, 2012 7:55 am
This would be very useful
http://jplayer.org/
Where Flash does not work.
Adendum
Post by Adendum » Fri Jul 27, 2012 2:35 pm
LOL....it's already on my To Do list...but I wont be able to get to it for a while, maybe one of the other builders will oblige.
haakoo
Post by haakoo » Fri Jul 27, 2012 5:40 pm
too bad it isnt supported by all browsers yet
Hans
stamjoe
Post by stamjoe » Fri Aug 03, 2012 7:40 am
kabubi wrote:Can we development this slide? http://alexdunphy.github.com/refineslide/ thxs
wow...!!!! Awesome slider.
Good day to all!!!!
Joe
amrajadhyaksha
Post by amrajadhyaksha » Sun Aug 05, 2012 8:14 pm
What am I suggesting here?
Perhaps too many things to many champions of the fora.
Or maybe, just sharing a beautiful experience that may perhaps be brought within one's capability.
Take a look....
http://www.healinghistories.org/
It's a demo site at codrops.
amrajadhyaksha
Nice Gallery, this
Post by amrajadhyaksha » Mon Aug 06, 2012 5:41 pm
http://www.dykinga.com/
Thumbnails softly slide in when you hover over the image.
Flash, but guess here everyone is into proving that what flash can do, jquery or css or HTML5 can do better.
AMEN.
