RECOMMEND THIS SITE/PAGE extension
Try this place a layer on your page drag the recommend extension on top of it use the fixed object extension but instead of trying to fix to the recommend a friend use the layer instead and you should now be able to scroll page having the recommend friend always in view
Try this wbs I have just made a very simple page with the recommend extension on it with a layer and the fixed object the recommend sits on the layer postioned in the header/banner when viewed it is to the left and when scrolling page it stays in the same position/...
http://www.mediafire.com/?zzkhjznyn2q
BaconFries wrote:Try this wbs I have just made a very simple page with the recommend extension on it with a layer and the fixed object the recommend sits on the layer postioned in the header/banner when viewed it is to the left and when scrolling page it stays in the same position/...
Thanks BF,
It appears the positioning problem was due to my using version 3 instead of version 4 of "Recommend this Site".
Now I have 2 different problems with it.
1) When I fix the position by using a Layer and the Recommend is displayed, it does not respond to being clicked except at either end of the text. eg. If the word is, say, "Recommend" then the pointer only becomes clickable on the start and the end of the word "Recommend".
Confused as anything about that one.
2) When I fix the position (using the Layer technique) it is visible in Page Preview at 1280x600 screen resolution and above, but at 800x600 and 1024x768 it is not visible at all.
Any ideas, chaps?
- me.prosenjeet
Did you fill all the variables correctly?
Hint:
Drag the extension on your page and double click on it to see the variables
Hint:
www.Lucknowwebs.com
www.Lucknowwebs.com
Have tried many things, myself, but with no joy on this.SKW wrote:That will be great, thanks.BaconFries wrote:Hmmm not sure what may be going on here but I will try and take a look at it for you and get back asap.....
On another matter, is it possible to remove underlining from the visible "Recommend" text?
Thanks.
Hi Guys, I use this extension with no problems. Could your ISP block this in any way? I have just checked two site and they work fine, why dont you see if you can send to yourself form my sites.
http://www.harddrivecctv.co.uk
http://www.schryver-restoration.com/
