RECOMMEND THIS SITE/PAGE extension
SKW
Post by SKW » Sun May 02, 2010 5:45 pm
morgan wrote:Hi SKW, i use this and must admit I also have the same problem.
http://www.schryver-restoration.com/
It does work well just a small typo error for me.prosenjeet
Hiya mate,
Thanks for replying (I thought it might be something I was doing wrong).
Any ideas on how to correct it? :?
Cheers.
morgan
Post by morgan » Sun May 02, 2010 6:28 pm
Hi SKW, better get in touch with the developer,
profile.php?mode=viewprofile&u=5515
Hope he can help.
me.prosenjeet
Post by me.prosenjeet » Sun May 02, 2010 6:39 pm
Extension no longer supported, you will have to edit the text on your server and in the project, right click on the extension and select "Do not publish" so next time you update the site, the changes you made on the server manually will not be over written by the extension
www.Lucknowwebs.com
morgan
Post by morgan » Sun May 02, 2010 7:15 pm
Hi me.prosenjeet,
Its a real shame you dont support this extension, for me being a real novice your resolution is just Gobbledygook. As you can see we do use these extension and are very greatful of the work that you do.
Regards morgan
SKW
Post by SKW » Sun May 02, 2010 7:31 pm
I have to agree with Morgan on this.
If we were programmers, we'd not be using WB.
"you will have to edit the text on your server and in the project, right click on the extension and select "Do not publish" so next time you update the site, the changes you made on the server manually will not be over written by the extension"
Means nothing to me. Might as well be in Chinese.
No offense intended. I love your extensions. I love this site and the help it offers but, shucks, I'm a newbie. You are light-years ahead of me. And if you give me a hand I promise not to try and catch up with you (like that would be possible). :D
me.prosenjeet
Post by me.prosenjeet » Sun May 02, 2010 7:53 pm
Ok, give me few days time... I am awfully busy these days. I will change that
www.Lucknowwebs.com
SKW
Post by SKW » Sun May 02, 2010 8:08 pm
cool.
That's what I meant when I said "I love this site".
Appreciated. :D
morgan
Post by morgan » Sun May 02, 2010 10:09 pm
Hi me.prosenjeet you will always sleep with a clear conscience.
Thank You :lol:
morgan
Post by morgan » Tue May 11, 2010 8:52 am
Hello me.prosenjeet,
Have you had any time for this, reason I ask is I am about to make some changes to this site and want to include it on another.
Many Thanks
morgan
Post by morgan » Sat May 22, 2010 10:04 pm
Hi me.prosenjeet,
How are you sleeping :lol:
Please can you advise if you are going to update this very useful extension.
morgan
me.prosenjeet
Post by me.prosenjeet » Sat May 29, 2010 8:38 pm
Extension updated V4 now.
"Should/Would" should not happen now
viewtopic.php?t=17119&postdays=0&postorder=asc&start=0
www.Lucknowwebs.com
SKW
Post by SKW » Sun May 30, 2010 7:56 am
Thanks for that.
Should I delete the Extension and download/install it again or do I need to do nothing
me.prosenjeet
Post by me.prosenjeet » Sun May 30, 2010 8:10 am
If you have the extension on your webpage, if you delete the earlier V3, your page will not open in WB as it will say V3 is missing. I suggest you download this and rename the extension to V3 instead of the actual name V4 and then paste/replace it in the install directory
www.Lucknowwebs.com
morgan
Post by morgan » Sun May 30, 2010 8:16 pm
:D (¯`'•.¸(¯`'•.¸(¯`'•.¸Thank You¸.•'´¯)¸.•'´¯)¸.•'´¯) :D
SKW
Post by SKW » Thu Jun 03, 2010 8:51 pm
A very useful extension but I would like to be able to lock it so that it is always available when someone scrolls down the page.
I've tried using the Translated Fixed Object extension, but that doesn't seem to work with Text Frames or Extensions (only shapes).
Any ideas/solutions, please.
