Webshop Plus! v.3.2 for WWB8
protectourlands
Re: Webshop Plus! v.3.2 for WWB8
Post by protectourlands » Fri Feb 20, 2015 4:36 pm
Thank you George
Should I use jQuery to do that, or do you have a recommended way to easily do this?
Navaldesign
Post by Navaldesign » Fri Feb 20, 2015 4:47 pm
No, just use WWB's built in form field validation
www.dbtechnosystems.com
protectourlands
Post by protectourlands » Fri Feb 20, 2015 4:52 pm
I don't see how to apply this in the WB validation.
This javascript seems to work though.
onkeyup="this.value=this.value.replace(',','')" value="" /
It's not perfect because it removes the character as it is typed. This may confuse the user.
Do you have a suggestion for using the WB validation? Thank you for looking at this.
Navaldesign
Post by Navaldesign » Fri Feb 20, 2015 5:27 pm
In both cases the comma MUST be removed, so the javascript is ok.
protectourlands
Post by protectourlands » Fri Feb 20, 2015 5:55 pm
Thanks George
i'll run with this. Let me know when you can address this in the app ad I can remove the js. I appreciate it.
Navaldesign
Post by Navaldesign » Sat Mar 14, 2015 3:35 pm
I'm not sure how to solve this. I would need the files creted on the server for the orders and the ordered products to see if I can do something.
Navaldesign
Post by Navaldesign » Wed Mar 25, 2015 4:49 am
You must upload the full backend part, as well as all the cart pages, and also adjust the settings in the backend, before the cart can work.
Please read the instructions included in the manual.
gevers
Post by gevers » Thu May 07, 2015 7:27 am
Is it possible to reset the username and password in de admin app ?
I forgoten this and now i need it. And i forgot also the mailadres
:cry:
gr. Gerrie
Navaldesign
Post by Navaldesign » Thu May 07, 2015 12:01 pm
To change the mails, right click the DBTS form processor in the "thankyou" page and set header and footer as you like them, lease see manual.
To see what your details are, open the file "config.php" on the server.
Navaldesign
Post by Navaldesign » Tue May 12, 2015 3:52 pm
You can apply the built in WWB validation for the Quantity field.
gforce7
Post by gforce7 » Fri May 15, 2015 4:20 pm
On the cart page and I click on the "Check out" button how do I skip it going to custom_details page? I'd like for it to go straight to customer info. I have looked at the page html but do not see where this is called. Also on the same cart page I would like to have the "Continue shopping" button go to a page with product listing.
This may have been covered and if so I apologize.
Allen
Navaldesign
Post by Navaldesign » Fri May 15, 2015 4:39 pm
1. Please set it as you like in the Admin area--> Custom Fields Settings --> Display Custom fields page ? --> Do not display custom fields page
2. Admin area --> PayPal Settings --> Continue Shopping URL --> Type the URL of the page where you want your customers redirected (the listings page).
gforce7
Post by gforce7 » Fri May 15, 2015 7:08 pm
Thank you. I thought It had to be something like that but kept overlooking those settings.
Navaldesign
Post by Navaldesign » Tue Jun 16, 2015 4:17 am
I'm sorry but without actually seeing your settings and testing it (to see what the issue is) I can't be of much help.
If you wish contact me through my site contact form.
Navaldesign
Post by Navaldesign » Fri Jun 26, 2015 8:24 pm
There is no way to set shipping by zip code.
In my professional carts, I have a routine that "comunicates" with UPS and retrieves the shipping charges directly from the UPS site based on shipment method, weight, origin zip and destination zip.
Unfortunately, this exceeds the features of a Free cart like Webshop Plus.
