WB15 64bit or 32bit
steveKersh
WB15 64bit or 32bit
Post by steveKersh » Thu Jun 27, 2019 6:55 pm
I just purchased and installed WB15 and it appears it is the 32bit version. Should it have installed the 64bit version?
Re: WB15 64bit or 32bit
Post by Pablo » Thu Jun 27, 2019 6:57 pm
If you previously used the 32bit version then you can continue to use that version.
steveKersh
Post by steveKersh » Thu Jun 27, 2019 7:02 pm
I was using the 64biut of WB14. But the install of WB15 is only 32bit.
Post by BaconFries » Thu Jun 27, 2019 7:23 pm
Are you sure you downloaded the 64-bit from the following??
https://www.wysiwygwebbuilder.com/forum ... =1&t=77283
steveKersh
Post by steveKersh » Thu Jun 27, 2019 7:24 pm
I downloaded from the link I was given when I purchased WB15. I will try your download link. Thanks.
alan_sh
Post by alan_sh » Thu Jun 27, 2019 7:26 pm
Yes, I made that mistake too. Maybe the purchase link needs to include both zip file links.
Alan
Post by BaconFries » Thu Jun 27, 2019 7:31 pm
At the following url below f you look you will see a link for WB15 which if clicked will take you to the download for the 64-bit at the url I gave above.
alan_sh
Post by alan_sh » Thu Jun 27, 2019 7:44 pm
Yes, but the link provided by the email only gives you the 32 bit version
Alan
