php Blog extension: How to install and use - Tutorial
Re: php Blog extension: How to install and use - Tutorial
You do not have to edit the HTML, the width of the object can be changed by moving the object handles.
Does anyone know how - once this blog is installed - the end-user (in this case, my client) will be able to ACCESS his blog and make posts? Is it some kind of a dashboard that he will log INTO? Or, does he have to access it through the same Wysiwyg Web Builder program that "I" used to create it?
If so, it's not really going to be "user-friendly" enough for my client to use.
Clark
Clark
Have you read the enclosed PDF and viewed the video tutorial? Please note that this is a user tutorial video so no official help is available on it, any help may come from the user who provided it and others wishing to help. But first carefully read all documentation and view the video carefully as this will give you a understanding on how to use.
Well, I think I am very close to getting the new blog tool to work and I appreciate being pointed to the tutorial. It was very helpful in getting this far.
I need a bit of help in getting it to work and if you feel inclined to help, I'm very grateful in advance.
Here is the link: http://www.compositeautomation.com/page1.html
I was able to get the confirmation that the database schema was created correctly.
1. Will the blog need a password to be accessed by the public?
2. Should I post the admin password here for any needed help? PM me at john at compositeautomation.com or here and I'll send it to you.
3. how do I fix the date?
4. Once I log in with the password, none of my test entries are displayed.
5. Recaptcha doesn't work.
I read through the PDF and watched the entire tutorial multiple times and followed everything step by step.
Hope you can fill in the missing pieces for me!
Thank you!!
John
Thank you!!
John
- me.prosenjeet
No, it is only for the admin
You may contact me here if you need further help with the WB blog: http://lucknowwebs.com/contact
Did you try posting something new? It should pick the date on its own
Are the test entries 'published'?
Did you set it while installing?
Also, check out the Tutorial section.
me.prosenjeet wrote: ↑Mon Sep 17, 2018 7:39 am1. Will the blog need a password to be accessed by the public?
OK. Good to know
I'll be in touch!
I did. I did not see it posted/published.
I don't believe they were published.
It has a message tthat recaptcha Vv1 isi shut down.
I tried multiple times and had no luck.
- me.prosenjeet
aeroflyte, thanks for contacting.
Your problem with WB blog has been sorted and communicated/mailed to you.
Please leave your feedback
