Sub-pages should open in an Inline Frame
Patr100
Post by Patr100 » Thu Jun 04, 2009 10:25 pm
Right thanks I think I just need the script on the sub pages so anyone finding them on Google will get taken to a navigation page.
kees
Post by kees » Thu Jun 04, 2009 10:39 pm
Patr100 wrote:Right thanks I think I just need the script on the sub pages so anyone finding them on Google will get taken to a navigation page.
... and did not get the page they were looking for :?
I would advice to perform the modifications on the main page as described.
Patr100
Post by Patr100 » Fri Jun 05, 2009 11:49 am
Yes you're right - I just thought as long as they find the nav they can make their own way but its not right to do that.
I'm having a slight problem so I may return when I have more time.
Does the following code need to be modified?
onLoad = "self.IFrameName.location.href = file"
kees
Post by kees » Fri Jun 05, 2009 2:13 pm
Patr100 wrote:Does the following code need to be modified?
Yes.
IFrameName should be changed to the name of your Inline Frame.
Patr100
Post by Patr100 » Fri Jun 05, 2009 3:06 pm
Thanks that was the bit I missed -
haakoo
Post by haakoo » Sun Oct 18, 2009 10:43 pm
Kees,
Small request to you.
Is it possible to add a variable to the javascript that can be a trigger for a javascript in the index page?
crude example of what i'm looking for
-put a variable called var sd on sub_1.html
-have it display in an editbox with document.getElementById(Editbox1).value =sd;
This to execute a javascript function on index page
Hans
haakoo
Post by haakoo » Mon Oct 19, 2009 11:33 am
Allready figured out how to do it.
Hans
kees
Post by kees » Mon Nov 23, 2009 5:21 pm
FAVTdk wrote:what have I done wrong
Can you give the exact url of the main page (with the iframe)?
kees
Post by kees » Mon Nov 23, 2009 10:35 pm
The inserted code at step 3a should be:
 if (top != self) top.location = self.location;
 var file = location.search ? unescape(location.search.substring(1)) : "./Velkommen/Velkommen.php";
</script>
electrochrisso
Re: Sub-pages should open in an Inline Frame
Post by electrochrisso » Fri Sep 05, 2014 10:34 pm
Not sure if I am missing something here, but all this can be done using the standard options provided by Web Builder, No!
Post by Pablo » Sat Sep 06, 2014 6:21 am
Please note that this topic is more than 5 years old. 'Kees' is no longer active on this forum.
However the script still works.
mnwitten
Post by mnwitten » Sun Jun 21, 2015 8:47 pm
I came up with this little piece of code that may help anyone interested.
<script>
// Get where the user came from
referrer = document.referrer.toLocaleLowerCase(); //new URL(document.referrer).hostname;
// If it isn't onlinewatersports...
if (referrer.indexOf("onlinewatersports")==-1)
// send them to the main website page
window.location="http://www.onlinewatersports.com";
</script>
It simply captures where the user browsed from. In this case...was it onlinewatersports? if it wasn't...it redirects them to the main page. I modified the code to post here so consider this untested.
