Forms in Masterpage
Issues related to forms.
Williams
Forms in Masterpage
Post by Williams » Sat Nov 09, 2019 12:22 pm
Hi All,
I've been using the form validations for a long time ago, However, I've been noticed that Form validations doesn't work Thru the master page.
Just to be clear, I've added an editbox to a layer, and set my validation. it works fine for all pages. but it doesn't while using same editbox in masterpage!!!
Thank you...
Re: Forms in Masterpage
Post by Pablo » Sat Nov 09, 2019 1:29 pm
What is the URL of the page, what are your exact settings or where can I download a demo project?
Williams
Post by Williams » Sat Nov 09, 2019 4:35 pm
The first form in the page only works when you enter your email and that's fine, the second one which created in master page works with/without entering an email however the setting is the same.
https://filebin.net/dchjduudb3z7xubp
Post by Pablo » Sat Nov 09, 2019 6:40 pm
Where exactly do I need to look to see the non-working form?
Williams
Post by Williams » Sun Nov 10, 2019 2:01 am
The news letter at the footer. The form could be successfully submitted however there's a validate.
Post by Pablo » Sun Nov 10, 2019 8:35 am
Thanks, support for form validation has been added in the latest build (11/10/2019)
http://wysiwygwebbuilder.com/download.html
Williams
Post by Williams » Tue Nov 12, 2019 1:17 am
Pablo,
Could you clarify more pls. What do you exactly mean with that! is this issue should be fixed once I've installed the new release of (11/10/2019)
Post by Pablo » Tue Nov 12, 2019 7:34 am
If you install the latest build (date: 11/10/2019) then forms validation is now also supported in master frames.
Williams
Post by Williams » Tue Nov 12, 2019 9:17 am
So Do i need to remove the form and re-create it again after installing the last build!!
Post by Pablo » Tue Nov 12, 2019 10:02 am
There is no need to redo the form. Just republish the page.
Williams
Post by Williams » Tue Nov 12, 2019 11:28 am
I'll give it a try & get back..
Many thanks Pablo.
