ABVFP A Powerfull Form Processor for WYSIWYG WB users!
Issues related to forms.
Patrik iden
Re: ABVFP A Powerfull Form Processor for WYSIWYG WB users!
Post by Patrik iden » Fri Nov 18, 2011 3:21 pm
Hi. Regards to waht we discused before:
When i add this '.$_POST['mailto'].' in the admin mail field in form processor the apge go blank?
And if take '.$_POST['mailto'].' away from the admin mail field, then the page works, but avcorse the adminmail is not sent.
However this seem to work whit the wwb8 mailform.
Navaldesign
Post by Navaldesign » Fri Nov 18, 2011 8:15 pm
I'm not sure I follow you. You are using the WWB built in form processor ? or the DBTS Form Processor ? Or ABVFP ?
www.dbtechnosystems.com
Patrik iden
Post by Patrik iden » Fri Nov 18, 2011 8:41 pm
Navaldesign wrote:I'm not sure I follow you. You are using the WWB built in form processor ? or the DBTS Form Processor ? Or ABVFP ?
Qurrently i am using WWB built in form processor, and that works by putting '.$_POST['mailto'].' in the Email Address filed. But i whant to use the DBTS Form Processor, but if i put the '.$_POST['mailto'].' in the Admin email filed and publish the page then the page goes blank.
Navaldesign
Post by Navaldesign » Fri Nov 18, 2011 8:54 pm
For DBTS Form processor you should use
".$_POST['mailto." (double quotes instead of single ones.
Please not that you should be more clear in what you are asking so we can know what you are using.....Not all cases / scripts are the same.
Patrik iden
Post by Patrik iden » Fri Nov 18, 2011 9:24 pm
Navaldesign wrote:For DBTS Form processor you should use
Thank you i'l try this. And i'l try to be more clear in the future.
Your help is priceless :lol:
Navaldesign
Post by Navaldesign » Fri Dec 16, 2011 8:48 am
As mentioned in your other thread, the DBTS Form Processor is better.
If, nevertheless, you prefer ABVFP, please download the zip, and read the manual that contains full instructions on how to install and use.
Joseph1982
Post by Joseph1982 » Mon Oct 05, 2015 10:18 am
hello Navaldesign,
I get this error message when sending form data from website:
Forbidden
You don't have permission to access /agent_apply.php on this server.
what is wrong with the form?
this is the link of agent apply page: http://eyfelparfum-co.ir/agent_apply.php
Navaldesign
Post by Navaldesign » Mon Oct 05, 2015 7:33 pm
I can't know, probably a permissions issue.
But, are you using the ABVP processor or the DBTS Form Processor ?
Are you on a Linux or a Windows hosting server?
What are the permissions of the page on the server ?
Joseph1982
Post by Joseph1982 » Mon Oct 12, 2015 7:41 am
Navaldesign wrote:I can't know, probably a permissions issue.
I am using DBTS Form Processor.
the hosting server is linux.
I have admin access to all pages on the server.
Navaldesign
Post by Navaldesign » Mon Oct 12, 2015 2:27 pm
Then it is most certainly a permissions issue. Make sure that all files are 644
Joseph1982
Post by Joseph1982 » Tue Oct 13, 2015 8:23 am
Navaldesign wrote:Then it is most certainly a permissions issue. Make sure that all files are 644
I checked all file permissions. All of them have 644 permission and -rw-r--r-- attributes.
Navaldesign
Post by Navaldesign » Tue Oct 13, 2015 1:36 pm
Then it could be an issue with the page code.
Please post the page code as you can see it in WWB.
Also check permissions of the folder "dbts_incudes" and the files within it.
Hurtado
Post by Hurtado » Sat Jul 02, 2016 7:36 am
Older
Update?
