Form calculation not working properly
Issues related to forms.
ruel.lago22
Post by ruel.lago22 » Sun Jun 16, 2019 12:01 pm
Hi Pablo!
A quick question regarding the form calculation. Radio boxes calculation seems to work just fine but if you add the extra below, instead it adds to the total it literally adds itself after the number total. I have attached the WBS file and you may use it unlock using my registered email address. The link where it is published is noted inside the WBS file. Thank you so much!
https://www.sendfilessecurely.com/getfi ... wfeD1FmVw3
Regards,
Ruel
Re: Form calculation not working properly
Post by Pablo » Sun Jun 16, 2019 12:26 pm
You will need to add the value as a number, not as a string.
Related tutorial:
https://www.wysiwygwebbuilder.com/conditions.html
(example 2)
ruel.lago22
Post by ruel.lago22 » Sun Jun 16, 2019 12:30 pm
Hi Pablo,
Got it. Thank you!
Regards,
Ruel
ruel.lago22
Post by ruel.lago22 » Sun Jun 16, 2019 12:50 pm
Hi again Pablo,
Sorry I have one another question in regards to condition to calculate in my extra service part. When they check it, it adds the amount to the total and it worked. I now add a condition where if it is unchecked it will deduct the amount again to the total. Can you please help me with this one, please.
I have attached the updated WBS file and you may unlock using my registered email address. The link where it is published is noted inside the WBS file. Thank you so much!
https://www.sendfilessecurely.com/getfi ... MgNm2AMtUU
Regards,
Ruel
Post by Pablo » Sun Jun 16, 2019 2:19 pm
At the moment I am very busy so I cannot help you with the implementation of your condition. For me, this usually also take a lot of time.
Note however that conditions is standard JavaScript functionality, so the same logic applies.
