Form fields layout
Issues related to forms.
terryfoster60
Form fields layout
Post by terryfoster60 » Fri Feb 01, 2019 4:19 pm
Okay - than you everyone for the help getting a form on a lyout grid.
I am now dragging the form objects to the screen and great this is working.
I can not seem to find anything that specifies the gaps between the elements - they are all bunching up.
I have downloaded the template Flowers and can not see how they have spaced out the fields
Thank you
Terry
Re: Form fields layout
Post by Pablo » Fri Feb 01, 2019 4:33 pm
You can add margin to elements with the 'margin' property.
terryfoster60
Post by terryfoster60 » Fri Feb 01, 2019 4:56 pm
Thank you - found where the Margin property was settable.
I knew it had to be margin but could not see it in the WYSIWYG interface.
I am familiar with website design and used dreamweaver for ages but WYSIWYG is a new ball game.
It is brilliant once you get used to it's handling and I am sure I will get what I want once I have managed to find out to handle her.
One last thing though regarding layout...
Is there a way to center the submit button... looked everywhere but it's not jumping at me.
Thank you for everything.
Terry
Post by Pablo » Fri Feb 01, 2019 5:46 pm
You can set the alignment of the column to center.
Or use a nested layout grid for only the button.
