I am having an issue with the email form WYSIWYG 14 64Bit version. The form keeps going to the error page.
Please try it. Link: http://www.liquidkittyband.com/contact_us.php
Any help would be appreciated.
Wayne
*** SOLVED *** Email Issue With 64Bit
http://www.wysiwygwebbuilder.com/forms.html
http://www.wysiwygwebbuilder.com/form_wizard.html
Frequently Asked Questions about Forms
- littlerocken
Re: Email Issue With 64Bit
What are your exact settings?
What is the generated (PHP) code?
Also, can you please remove all custom code from the page?
Hi, Wayne
i see you use two contact forms at same page, looking design, i not see reason why use two, when can use one, anyway, before here i read somewhere Pablo recommend to only use one form per page. if remeber good.
So suggestions is to use all in one contact form
<div id="wb_contactwhite1"> and <div id="wb_contactwhite2"> can be one
- littlerocken
I reworked everything and it's working fine.
Thank you!
Thank you!
I must say design is Very Good, nice work, and nice fonts
Nice site, looking at your song list, I would definately hire you guys for my party, I am listening to your video now, not bad at all.
Might be a good idea to create new video material though, without the audience noise interferance.
