Auto Responder
Issues related to forms.
curtis@phantech.com
Auto Responder
Post by curtis@phantech.com » Fri Oct 19, 2018 8:35 pm
Enabling Auto Responder sends out 2 emails. How do I change that to only send 1 email?
Re: Auto Responder
Post by Pablo » Sat Oct 20, 2018 7:12 am
This is most likely caused by conflicting settings or multiple forms on the same page.
What exactly did you do?
What are you settings?
What is the generated PHP code?
curtis@phantech.com
Re: Auto Responder
Post by curtis@phantech.com » Sat Oct 20, 2018 5:49 pm
I get 2 emails. One from you my page the other from my ISP
Re: Auto Responder
Post by Pablo » Sat Oct 20, 2018 5:57 pm
To be able to help you I need more details.
Can you please answer those questions?
- What exactly did you do?
- What are your exact settings?
- What is the generated PHP code (Page HTML)?
or else:
viewtopic.php?f=10&t=82134
curtis@phantech.com
Re: Auto Responder
Post by curtis@phantech.com » Sun Oct 21, 2018 4:25 pm
<?php
function ValidateEmail($email)
$pattern = '/^([0-9a-z]([-.\w]*[0-9a-z])*@(([0-9a-z])+([-\w]*[0-9a-z])*\.)+[a-z]{2,6})$/i';
return preg_match($pattern, $email);
if ($_SERVER['REQUEST_METHOD'] == 'POST' && isset($_POST['formid']) && $_POST['formid'] == 'form2')
$mailto = 'support@phantech.com';
$mailfrom = isset($_POST['email']) ? $_POST['email'] : $mailto;
$subject = 'Message from InfoRecall Contact ';
$message = 'A Contact Message from InfoRecall';
$success_url = './sent.html';
$error_url = './problem.html';
$error = '';
$autoresponder_from = 'PhantechSoftware';
$autoresponder_to = isset($_POST['email']) ? $_POST['email'] : $mailfrom;
$autoresponder_subject = 'Message from Phantech Software';
$autoresponder_message = 'Thanks for contacting us. We\'ll respond as soon as possible. Your satisfaction is important to us.
$eol = "\n";
$boundary = md5(uniqid(time()));
$header = 'From: '.$mailfrom.$eol;
$header .= 'Reply-To: '.$mailfrom.$eol;
$header .= 'MIME-Version: 1.0'.$eol;
$header .= 'Content-Type: multipart/mixed; boundary="'.$boundary.'"'.$eol;
$header .= 'X-Mailer: PHP v'.phpversion().$eol;
if (!ValidateEmail($mailfrom))
$error .= "The specified email address is invalid!\n<br>";
if (!empty($error))
$errorcode = file_get_contents($error_url);
$replace = "##error##";
$errorcode = str_replace($replace, $error, $errorcode);
echo $errorcode;
exit;
$internalfields = array ("submit", "reset", "send", "filesize", "formid", "captcha_code", "recaptcha_challenge_field", "recaptcha_response_field", "g-recaptcha-response");
$message .= $eol;
$message .= "IP Address : ";
$message .= $_SERVER['REMOTE_ADDR'];
$message .= $eol;
$logdata = '';
foreach ($_POST as $key => $value)
if (!in_array(strtolower($key), $internalfields))
if (!is_array($value))
$message .= ucwords(str_replace("_", " ", $key)) . " : " . $value . $eol;
else
$message .= ucwords(str_replace("_", " ", $key)) . " : " . implode(",", $value) . $eol;
$body = 'This is a multi-part message in MIME format.'.$eol.$eol;
$body .= '--'.$boundary.$eol;
$body .= 'Content-Type: text/plain; charset=ISO-8859-1'.$eol;
$body .= 'Content-Transfer-Encoding: 8bit'.$eol;
$body .= $eol.stripslashes($message).$eol;
if (!empty($_FILES))
foreach ($_FILES as $key => $value)
if ($_FILES[$key]['error'] == 0)
$body .= 'Content-Type: '.$_FILES[$key]['type'].'; name='.$_FILES[$key]['name'].$eol;
$body .= 'Content-Transfer-Encoding: base64'.$eol;
$body .= 'Content-Disposition: attachment; filename='.$_FILES[$key]['name'].$eol;
$body .= $eol.chunk_split(base64_encode(file_get_contents($_FILES[$key]['tmp_name']))).$eol;
$body .= '--'.$boundary.'--'.$eol;
if ($mailto != '')
mail($mailto, $subject, $body, $header);
$autoresponder_header = 'From: '.$autoresponder_from.$eol;
$autoresponder_header .= 'Reply-To: '.$autoresponder_from.$eol;
$autoresponder_header .= 'MIME-Version: 1.0'.$eol;
$autoresponder_header .= 'Content-Type: text/plain; charset=ISO-8859-1'.$eol;
$autoresponder_header .= 'Content-Transfer-Encoding: 8bit'.$eol;
$autoresponder_header .= 'X-Mailer: PHP v'.phpversion().$eol;
$autoresponder_message .= ucwords(str_replace("_", " ", $key)) . " : " . $value . $eol;
else
$autoresponder_message .= ucwords(str_replace("_", " ", $key)) . " : " . implode(",", $value) . $eol;
mail($autoresponder_to, $autoresponder_subject, $autoresponder_message, $autoresponder_header);
header('Location: '.$success_url);
exit;
Re: Auto Responder
Post by Pablo » Sun Oct 21, 2018 5:28 pm
The code is correct, only one email is sent by the auto responder script.
Note however that the email is also set to 'support@phantech.com', so if you use the same email for testing then you will receive two emails.
curtis@phantech.com
Re: Auto Responder
Post by curtis@phantech.com » Mon Oct 22, 2018 12:16 am
I'm plenty dumb!
That's exactly what I did.
Thanks for pointing it out.
