Form not sending [SOLVED]
Issues related to forms.
bry
Post by bry » Sun Sep 16, 2018 11:28 pm
I checked the FAQ and have changed the email to one within the domain but that still doesn't work. The host definitely allows php.
The website is http://www.senatorligon.com/join.php
Thanks for any help.
bry
Re: Form not sending
Post by bry » Mon Sep 17, 2018 12:22 am
Somebody sent a test that came in IP 86.29.146.___ came in, city metown, state 12345, from me code a bloody mess. I do not understand why your test came but mine won't. I tried a gmail address.
Any ideas??
Post by Pablo » Mon Sep 17, 2018 5:50 am
Did you check your spam?
Either the host is blocking the email or is blocked by a (spam) filter.
bry
Post by bry » Mon Sep 17, 2018 11:26 am
Yes, we checked spam folder. I will contact Dreamhost.
Thanks much.
Do you know why those emails take so long 6-7 hours to come in?
Post by Pablo » Mon Sep 17, 2018 12:12 pm
The emails are sent by the server of the host, so only they can explain why it takes so long.
Note that this is not normal behavior.
bry
Post by bry » Mon Sep 17, 2018 12:13 pm
Thanks, i will ask them!!
bry
Post by bry » Wed Sep 19, 2018 12:13 am
The problem was that I did not have an email from that domain listed in the "from" window. Just go to object properties of the form.
Out from the "Email address" click on "More" and then be sure to put a domain email in the from window. That fixed it and they now
arrive within minutes.
My bad.
