Expanding Layer
Issues related to forms.
GPK5050
Expanding Layer
Post by GPK5050 » Thu May 24, 2018 1:29 pm
Hi...
I have a page on my website that had a HTML code box for using the program "DISQUS". This app is basically a message board... the more messages, the longer the box that the messages appear in gets.
Is there a way so that the layer that the code box is in will expand automatically so it will contain the message board? Right now, the program goes below the layer page and into the footer.
http://carpenters50th.com/discus.html
Thank you...
Greg
Re: Expanding Layer
Post by Pablo » Thu May 24, 2018 1:43 pm
This is only possible if you use flexible layout with layout grids.
If you use fixed layout then all objects have a fixed size and position, so if one of these objects expands then it will overlap the rest of the layout.
Related tutorial:
http://www.wysiwygwebbuilder.com/layout_modes.html
GPK5050
Re: Expanding Layer
Post by GPK5050 » Thu May 24, 2018 1:55 pm
So, can one page of my site use this new format and still work properly with the Master Frame that is already in place?
Thanks...
Greg
Re: Expanding Layer
Post by Pablo » Thu May 24, 2018 2:07 pm
You will also need to create a new master frame with flexible elements.
See 'How to use Master Frames with Layout grids?'
http://www.wysiwygwebbuilder.com/master_frame.html
