Checkbox issue (Bug)
Issues related to forms.
GrahamW
Post by GrahamW » Tue May 22, 2018 5:20 am
Not sure if this is a bug but if you add a form layer to the page and add some check boxes and edit boxes then double click the check box and add a javascript event like this for the onclick
Editbox2.value='50';
Then preview the page and you will see edit box 2 will end up with a value of 50 but you dont see the check in the checkbox. If you remove the javascript the checkbox will display the check.
Is this a bug or not.
It does the same with any javascript value in there not just what I typed above
Graham
Re: Checkbox issue (Bug)
Post by Pablo » Tue May 22, 2018 6:05 am
This is not a bug.
Please see this related FAQ:
https://www.wysiwygwebbuilder.com/forum ... 10&t=37833
