Form Confirmation Number
Issues related to forms.
GPK5050
Post by GPK5050 » Mon May 14, 2018 4:18 pm
Hi...
Is there a way for the form to generate a confirmation number and forward it to the person filling out the form once it's submitted as well as including it into the data being sent from the form?
Thank you....
Greg
Re: Form Confirmation Number
Post by Pablo » Mon May 14, 2018 4:47 pm
The webshop example has such a feature which generates a unique order number maybe viewing the tutorial will be helpful?
http://wysiwygwebbuilder.com/webshop.html
GPK5050
Post by GPK5050 » Mon May 14, 2018 5:17 pm
Thank you...
I will give it a look!
Greg
GrahamW
Post by GrahamW » Mon May 21, 2018 5:18 am
Hi Greg
I have a php mail form and an Reference Number Extension that I have designed that gives HTML output and has the following
Auto responder
Reference number
HTML Format email
here is what you receive when the client submits an email, notice the reference number in subject and body of email
http://www.screencast.com/t/il3ut9eS
Then the client also gets an auto responder and it looks like this
http://www.screencast.com/t/Gl2lyaBVhnG
To see it in action visit my site here www.grahamscomputers.net/contact.html
Put your name in the name filed and see the reference number above it generate
Graham
GPK5050
Post by GPK5050 » Mon May 21, 2018 1:59 pm
Hi...
Where did you get the code from? That's exactly what I'm looking for...
I'm trying to add it to this page...
www.carpenters50th.com/registration8.php
Thanks...
Greg
GrahamW
Post by GrahamW » Mon May 21, 2018 3:39 pm
Hi Greg
Send me a message from my sites listed above and I will send you my reference number extension.
Note that it's only the reference number part not my full php HTML email script
Graham
petejos
Post by petejos » Fri Jul 27, 2018 1:21 am
Hi Greg
Auto responder
Reference number
HTML Format email
Graham
How do you make that looks of what your client gets?
GrahamW
Post by GrahamW » Fri Jul 27, 2018 3:07 am
Hi Petejos
The reference number is a free extension I made for web builder you can download it from here
https://shop.grahamscomputers.net/index.html
As to the rest of the form and the layout that the customer gets its all done in a php mail script that I wrote that gives nice html formatted email.
You need to know a little bit of html to setup the form and the auto responder part within it but other that that its all straight forward
Graham
petejos
Post by petejos » Fri Jul 27, 2018 3:27 am
Hi Petejos
Graham
Thanks Graham. I accidentally paid you $1 for the extension because I didn't realise there is a download link. Anyway, thanks and all good.
petejos
Post by petejos » Fri Jul 27, 2018 3:59 am
Hi Petejos
Graham
Hi graham
I followed your wonderful instructions and it works. However, I can't get the reference number appear in the subject line of the emails to the responder and myself. Could you please advise what I might have missed as I have looked through your instructions again but can't seems to find any error. Thanks.
http://goec.com.au/goec2/testform.php
GrahamW
Post by GrahamW » Fri Jul 27, 2018 4:39 am
Just sent you a test message Peter. If you phone me as Im in NSW I can log onto your pc and take a look if you like.
Graham
