form number missing
Issues related to forms.
katman
form number missing
Post by katman » Sun Dec 03, 2017 6:16 am
I have set up a shopping cart which works perfectly in preview but not when loaded live onto website server which has php enabled and the page is .php.
When add to shopping cart is pressed, there is a notice the cart is empty instead of popping up with the item listed. Also, the price at the bottom of the page is blank. Below is the preview.
Do I have to enable something?
Online live version
Re: form number missing
Post by Pablo » Sun Dec 03, 2017 8:23 am
Which shopping cart did you use?
What is the URL of the page?
What are your settings?
katman
Post by katman » Sun Dec 03, 2017 8:24 am
paypal mini cart is being used for the whole page and it works fine for the other items and in preview.
os0 is Pitch
os1 is offset
Price is amount with ID "total"
custom sprocket form
I have used the search function for paypal on the forum and read the existing links on the 6 pages I found. I am not being lazy, I also watched the Spanish WB tutorial on paypal forms on YouTube by Hernán Pena though I don't speak Spanish it was quite helpful. And I have looked through a number of paypal's variable pages
Post by Pablo » Sun Dec 03, 2017 11:38 am
The form needs and 'action', it may not be empty.
Please see the configuration of the other forms.
Note that there is no support on (free) extensions. The extension is provided "AS IS".
katman
Post by katman » Sun Dec 03, 2017 7:54 pm
Thanks for looking into this Pablo,
The pricing is working now but not the shopping cart.
PAYpal is in the action
Post by Pablo » Sun Dec 03, 2017 9:01 pm
The form has two 'amount' fields. Maybe that is the problem?
katman
Post by katman » Sun Dec 03, 2017 11:51 pm
two? I can only see one, I will look harder, thanks
katman
Post by katman » Mon Dec 04, 2017 3:32 am
sorry, spoke too soon, it is not working. I thought I had it working but it is still only working in preview mode and not live.
I am at a loss to know why it works perfectly in preview (firefox and chrome) but not live on the server.
The tutorial I followed was posted in 2017 and mine works just like his in preview only. https://www.youtube.com/watch?v=MGJurSPABFE
If I simply ad 5.00 to the "EDITBOX" "TOTAL" "AMOUNT" value, shopping cart adds item but then the calculation does not work.
If I leave "AMOUNT" value blank, shopping cart will not add item as seen in the link below. The only difference between the one that works and the one that does not is 5.00 in the amount value. I have cut and pasted the form and only changed names to avoid conflicts.
The problem seems to be with the "editbox", or the amount value can't be left blank.
The WB tutorial I watched on line, leaves the amount value empty when using the calculation option. I just can't seem to get it working live, only in preview.
This works perfectly in preview with the amount value empty;
Post by Pablo » Mon Dec 04, 2017 6:56 am
The form still has two amount fields. Please remove the one in "hidden fields".
katman
Post by katman » Mon Dec 04, 2017 7:02 am
I am sorry, I must be blind because I don't see two "amount" in form.
Post by Pablo » Mon Dec 04, 2017 7:04 am
You also have an input field with the name 'amount'. The one in 'Hidden Fields' should be removed.
katman
Post by katman » Mon Dec 04, 2017 7:08 am
Do you mean this one? If so, this is how it is demonstrated in the tutorial and why does it work in preview?
Both forms are set up exactly the same way but only one does not work. I am sorry if I am not understanding or seeing something Pablo.
I removed it from hidden fields and reuploaded and still the same, cart empty. Also, the one that has both "amount" in hidden and input field is working?
Post by Pablo » Mon Dec 04, 2017 7:11 am
Yes
There may be an error in the tutorial. Having two fields with the same name is not valid.
It may work under some circumstances but the code is wrong, so there is no guarantee it will always work.
katman
Post by katman » Mon Dec 04, 2017 7:19 am
Ok, I removed it, still is not working.
