Conditions problem on form
Issues related to forms.
Jerry
Post by Jerry » Wed Nov 08, 2017 5:01 pm
Hi All... I need your expert help..again!
I created this form https://www.edesignsplans.ca/e-designs_ ... t_form.php
in WB 12 and it works great except I am having problem some conditions.
What I have tried to do is have conditions on all fields so they have to be filled in before the "Submit" button is shown.
The "Input plan Number" (which requires 7 numbers) works fine.
But after I enter a name in the "Name" box go onto the Address box, the "Submit" button comes on
I don't want it to come on until all required field are filled out..
Anyone known what I maybe doing wrong?
Thank you
Jerry
Re: Conditions problem on form
Post by Pablo » Wed Nov 08, 2017 6:29 pm
What you want cannot be done with conditions, because the conditions of the different objects conflict with each other.
This requires a JavaScript function.
Jerry
Post by Jerry » Wed Nov 08, 2017 6:36 pm
Thanks for your reply.
Is there not a way to have them group everything into one condition that I have placed under "Your Information"?
I don't know much about what I'm doing but even less using Java Script.. lol
Post by Pablo » Wed Nov 08, 2017 7:15 pm
No, not with the standard actions, you will need to create a custom function (which you can trigger using Form Conditions).
Here's a demo project, just to give you an idea:
http://www.wysiwygwebbuilder.com/suppor ... custom.zip
Jerry
Post by Jerry » Wed Nov 08, 2017 7:19 pm
OK..Thanks.
I'll give a try.
Users browsing this forum: No registered users and 7 guests
