CONTACT FORM
Issues related to forms.
kaleauto
CONTACT FORM
Post by kaleauto » Fri Nov 03, 2017 12:33 pm
Hi
we have a problem on contact form . we have below error message when we try to send a message via form .
"PHPMailer error: SMTP connect() failed. https://github.com/PHPMailer/PHPMailer/ ... leshooting "
https://ibb.co/d4WXsb our settings ....
our php code settings are as below
require("class.phpmailer.php");
$mail = new PHPMailer();
$mail->IsSMTP();
$mail->Host = "mail.cncservo.com";
$mail->SMTPAuth = true;
$mail->Username = "info@cncservo.com";
$mail->Password = "xxxx";
$mail->Port = 587;
$mail->From = "info@cncservo.com";
$mail->Fromname = "giden ismi";
$mail->AddAddress("info@alanadi.com","Ornek Isim");
$mail->Subject = $_POST['baslik'];
$mail->Body = implode(" ",$_POST);
if(!$mail->Send())
echo "Mesaj Gönderilemedi <p>";
echo "Mailer Error: " . $mail->ErrorInfo;
exit;
echo "Mesaj Gönderildi";
Re: CONTACT FORM
Post by Pablo » Fri Nov 03, 2017 1:06 pm
The error indicates that the SMTP server settings are incorrect.
Note that you will need to use your web host's SMTP server, not your ISP.
kaleauto
Re: CONTACT FORM
Post by kaleauto » Mon Nov 06, 2017 9:54 am
we used our server suplier's smtp settings .Do you think our setting are incorrect ?
Re: CONTACT FORM
Post by Pablo » Mon Nov 06, 2017 10:19 am
Only your webhost can verify whether the settings are correct.
The error message (generated by the server) indicates that the settings are not correct:
