Form Dilemma
Issues related to forms.
gofrank
Form Dilemma
Post by gofrank » Thu Nov 02, 2017 11:49 pm
I have a client who has requested a form with multiple combo boxes. For this example, I'll call them combo1 and combo2.
Combo1 has a yes/no selection. If the selection is "Yes", combo2 is disabled as being unnecessary. If combo1 is "No", combo2 is enabled. All this works great with the Conditions in WB12.
However...
Combo2 is a required selection IF it is enabled. Unfortunately, when combo2 is disabled, the validation code insists on requiring a selection (which isn't possible).
Is there a way to a) disable the required property if combo2 is disabled, or b) modify the validation code so that it checks for combo2 being enabled (as well as a selection being made) before displaying the alert requiring a selection?
Something like:
if (theForm.combo2.selectedIndex < 0) && (!theForm.combo2.disabled)
      alert("Please indicate a selection.");
      theForm.combo2.focus();
      return false;
(Pardon my rough code example. My Javascript is very rusty!)
Billing clients for your freelance work? Try Minute-2-Minute, the project management, timing, and billing system. Perfect for web developers who charge by the hour. FREE 45-day trial.
Re: Form Dilemma
Post by [RZ] » Fri Nov 03, 2017 5:31 am
are you sure you need 2 combos?
maybe you need just one checkbox (to make the combo visible or not via events) and the combo itself to get the relevant value
or
perhaps this may help you? viewtopic.php?f=53&t=77382
Re: Form Dilemma
Post by Pablo » Fri Nov 03, 2017 7:04 am
There is no standard solution for this.
So you will need to disable the built-in validation and implement your own code.
or check out rz's solution.
gofrank
Re: Form Dilemma
Post by gofrank » Fri Nov 03, 2017 12:31 pm
The visibility is not the problem. It's the validation. Regardless of the control's visibility or being disabled, the validation is still in effect. Unfortunately, my client is requiring both responses to be included on the form.
Nonetheless, thanks for the feedback. I'll explore Pablo's suggestion of a separate validation process.
gofrank
Re: Form Dilemma
Post by gofrank » Fri Nov 03, 2017 4:31 pm
Okay, here's a solution that works (for the benefit of anyone else who runs into this sort of problem). Thanks to WB's flexibility, it worked out to be fairly simple.
First, I removed all the validation from combo2 on the form.
Then, in the form's submit button HTML, I added this code to the "Inside Tag" tab:
onclick="return ValidateAltCombo();"
Finally, I went to the Page HTML section, and added this code to the "Before </body>" tab:
function ValidateAltCombo()
   var c = document.getElementById("combo2");
   if ((c.selectedIndex < 1) && (!c.disabled))
      alert("Please make a selection in combo2.");
      c.focus();
      return false;
</script>
The combo box .selectedIndex is tested for less than 1 as the first selection in the combo is not allowed (the index of the first selection is zero). The alert is displayed only if no selection has been made in combo2 AND combo2 is not disabled.
