probleme après submit
Issues related to forms.
dahdah
Post by dahdah » Fri Oct 27, 2017 7:48 pm
j'ai réalisé un forum après click sur submit les donneés sont envoyés à la base des donneés mais il sort ce message
Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in C:\AppServ\www\exmpl\index.php on line 114
Warning: date(): It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected the timezone 'UTC' for now, but please set date.timezone to select your timezone. in C:\AppServ\www\exmpl\index.php on line 115
voila le fichier index.php ou l'érreure apparetre
mysqli_query($db, "INSERT INTO $mysql_table (`DATESTAMP`, `TIME`, `IP`, `BROWSER`)
VALUES ('".date("Y-m-d")."',
'".date("G:i:s")."',
.$_SERVER['REMOTE_ADDR']."',
'".$_SERVER['HTTP_USER_AGENT']."')")or die('Failed to insert data into table!<br>'.mysqli_error($db));
$id = mysqli_insert_id($db);
foreach($form_data as $name=>$value)
Re: probleme après submit
Post by Pablo » Fri Oct 27, 2017 7:53 pm
You can add the following code to the start of the page to define a timezone:
<?php
date_default_timezone_set('America/New_York');
More info:
http://php.net/manual/en/function.date- ... ne-set.php
dahdah
Post by dahdah » Fri Oct 27, 2017 8:00 pm
merci mon maitre c'est bon merci
