Emailform without losing data with captcha error.
Issues related to forms.
Navaldesign
Re: Emailform without losing data with captcha error.
Post by Navaldesign » Thu Sep 01, 2011 5:22 pm
The confirm page should only display if a form submission has taken place.
So simply I have added this code in Start of Page:
<?php
if($_SERVER['REQUEST_METHOD'] != 'POST')
header('Location: index.php');
www.dbtechnosystems.com
mhn-pc
Post by mhn-pc » Thu Sep 01, 2011 5:28 pm
If I use the Built-in PHP form processor, Is there no problem ?
mhn-pc
Post by mhn-pc » Thu Sep 01, 2011 5:44 pm
I tested with the Built-in PHP form processor, unfortunately does not work !
What should I do?
Navaldesign
Post by Navaldesign » Thu Sep 01, 2011 6:25 pm
Why not ?
The project principles also apply if you use the built in processor. You ar eprobably doing something wrong.
Of course, using the built in processor modifies the behavior and you need to fix this yourself.
mhn-pc
Post by mhn-pc » Thu Sep 01, 2011 8:21 pm
I wrote the code, Please download this project !
SampleContact.wbs
Navaldesign
Post by Navaldesign » Thu Sep 01, 2011 8:32 pm
I'm sorry, but I don't understand. Why would you need this ?
Using the built in form processor the form submission takes place within your primary page (on the contrary of my example project.
Further more, this thread was about "remembering" the values of the form fields after an error. What does the project you attached here has to do with this ?
mhn-pc
Post by mhn-pc » Thu Sep 01, 2011 8:56 pm
For example, in your project !
When that entering the confirm.php page (for example: http://www.dbtechnosystems.com/wb5/confirm.php), comes the first page (index.php).
I want to do it in my project, I've attached the project and inserted the following code in the success page.
<?php
But it did not work !
Why did not it?
Where is the problem ?
Navaldesign
Post by Navaldesign » Thu Sep 01, 2011 9:02 pm
Please understand that these are two different things. In the example project, the processing code is in the "confirm" page. So I have added this code to redirect to "index" if someone tries to reach the confirm page WITHOUT form submission.
In your case, the processing code is in the first page. So there is no reason to do the redirect from the second to the first.
mhn-pc
Post by mhn-pc » Thu Sep 01, 2011 9:12 pm
Navaldesign wrote:So I have added this code to redirect to "index" if someone tries to reach the confirm page WITHOUT form submission.
I like it !
I want to without confirmation is not directed to the success page, of course in the my project !
Navaldesign
Post by Navaldesign » Thu Sep 01, 2011 9:43 pm
Just add the code I told you in start of Page of the "success" page !
mhn-pc
Post by mhn-pc » Thu Sep 01, 2011 10:12 pm
I did, but it did not work.
Please see this video !
http://www.mediafire.com/?muxurogr5kcku34
Navaldesign
Post by Navaldesign » Fri Sep 02, 2011 6:41 am
Maybe you have not understood that you should NOT put this code in your St_msg page. Because, in YOUR project, the processing code is in the "index" page, so there is NO reason why you should put the code in the ST_msg page.
In the example project page the code was there because it also contained the processing code.
There is no reason in your case to do so. and you can NOT do so, otherwise, after each submission, it will always redirect to the index page, so it will not display at all!
mhn-pc
Post by mhn-pc » Fri Sep 02, 2011 9:16 am
Thank you for your response. :)
