Publishing defaults to the wrong location
alan_sh
Post by alan_sh » Tue Jan 19, 2021 5:41 pm
I have about 10 default locations stored in WYSIWYG to match the 10 sites I work with. Each site knows which is it's own default location and all is fine. Until recently.
Ever since I upgraded to 16.1 (I think that's when it started - may have been before), when I do a new update, the default location for my sites gets screwed up and I have to reset each of them.
Is this a known issue? Where do you save this information and is it somewhere I can get at to see what it's set to?
cheers
Alan
WWBman
Re: Publishing defaults to the wrong location
Post by WWBman » Tue Jan 19, 2021 6:13 pm
They are stored in C:\Users\.....\Documents\WYSIWYG Web Builder\system\publish.dat
Post by Pablo » Tue Jan 19, 2021 6:17 pm
This functionality has not changed in recent updates
But the publish.dat file may be read-only or protected by your firewall/virus scanner.
alan_sh
Post by alan_sh » Tue Jan 19, 2021 7:22 pm
I'll check it out before and after the next update
cheers
Alan
alan_sh
Post by alan_sh » Tue Jan 19, 2021 7:29 pm
I had a quick look at publish.dat and I can't see what associates a profile with a particular .WBS file.
Where should I look for that?
Alan
Post by Pablo » Tue Jan 19, 2021 9:19 pm
The publish locations (server, user, passwords) are stored in publish.dat
The project only stores the name of the profile.
So, make sure all profiles have a unique name.
alan_sh
Post by alan_sh » Tue Jan 19, 2021 11:43 pm
Thanks Pablo.
What if one profile is "GMN Scouts" and another is "GMNSCcouts" - will they appear to be the same?
Alan
Post by Pablo » Wed Jan 20, 2021 7:18 am
No, these should be seen as two different profiles.
alan_sh
Post by alan_sh » Wed Jan 20, 2021 10:31 am
OK - it's not that then.
I'll install the latest hotfix later today and see what happens.
Alan
Post by Pablo » Wed Jan 20, 2021 10:32 am
I do not think the hotfix will make any difference. Nothing has changed related to publishing.
WWBman
Post by WWBman » Wed Jan 20, 2021 11:26 am
When you created the Publish profiles did you give each one a different Description?
I'm pretty sure this is used as the profile name in publish.dat, so as Pablo said, make sure these are unique.
Correct me if I'm wrong Pablo.
alan_sh
Post by alan_sh » Wed Jan 20, 2021 12:06 pm
Well I've just done an update and all is working as it should. I'll just keep an eye on things and see if I can see why it happened.
Alan
