Publishing web content to the domain fail
ohisiojohn
Post by ohisiojohn » Thu Dec 05, 2019 6:44 pm
Hi Pablo,
I am trying to upload my project to the domain but giving me this error. What can be done ?
*** START OF PUBLISH ***
Scanning publish folder...
Found 66 file(s).
SecureFtpLog:
Connect_Ftp2:
DllDate: Aug 30 2017
SecureFtpVersion: 9.5.0.69
UnlockPrefix: PBLVND.CB1072018
Architecture: Little Endian; 32-bit
Language: Visual C++ 6.0
VerboseLogging: 0
ProgressMonitoring:
enabled: no
heartbeatMs: 0
sendBufferSize: 65536
--ProgressMonitoring
Using Implicit SSL
ImplicitSsl: 1
AuthTls: 0
AuthSsl: 0
ftpConnect:
Hostname: ftp.visions-academy.org
Port: 990
Connecting via SSL/TLS
IdleTimeoutMs: 60000
socket2Connect:
connect2:
connectImplicitSsl:
connectSocket:
connect_ipv6_or_ipv4:
resolveHostname6:
getAddressInfo:
Failed to get host address info. (3)
SocketError: WSAHOST_NOT_FOUND No such host is known.
hostOrIpAddr: ftp.visions-academy.org
port: 990
Versions of Windows earlier than Windows XP are limited to handling IPv4 only
On Windows Server 2003 and Windows XP, IPv6 addresses are returned only if IPv6 is installed on the local computer.
--getAddressInfo
--resolveHostname6
Domain to IP address resolution failed.
--connect_ipv6_or_ipv4
--connectSocket
--connectImplicitSsl
ConnectFailReason: DNS lookup failed
--connect2
--socket2Connect
ConnectFailReason: 2
--ftpConnect
Failed to connect to FTP server.
Failed.
--Connect_Ftp2
--SecureFtpLog
SecureFtpLog:
Connect_Ftp2:
VerboseLogging: 0
ProgressMonitoring:
enabled: no
heartbeatMs: 0
Using Implicit SSL
ImplicitSsl: 1
AuthTls: 0
AuthSsl: 0
ftpConnect:
Port: 990
socket2Connect:
connect2:
connectImplicitSsl:
connectSocket:
resolveHostname6:
getAddressInfo:
port: 990
--getAddressInfo
--resolveHostname6
--connectSocket
--connect2
--socket2Connect
--ftpConnect
Failed.
--Connect_Ftp2
--SecureFtpLog
SecureFtpLog:
Connect_Ftp2:
VerboseLogging: 0
ProgressMonitoring:
enabled: no
heartbeatMs: 0
Using Implicit SSL
ImplicitSsl: 1
AuthTls: 0
AuthSsl: 0
ftpConnect:
Port: 990
socket2Connect:
connect2:
connectImplicitSsl:
connectSocket:
resolveHostname6:
getAddressInfo:
port: 990
--getAddressInfo
--resolveHostname6
--connectSocket
--connect2
--socket2Connect
--ftpConnect
Failed.
--Connect_Ftp2
--SecureFtpLog
Removing temporary files...
Publish failed!
*** END OF PUBLISH ***
Re: Publishing web content to the domain fail
Post by Pablo » Thu Dec 05, 2019 9:10 pm
The error indicates that the host address is not valid.
Are you sure the FTP configuration is correct?
Can you connect to the same address with another tool?
jerryco
Post by jerryco » Thu Dec 05, 2019 9:12 pm
How long ago did you register the domain name? It may take up to 24-48 hours for it to be available anywhere...
ohisiojohn
Post by ohisiojohn » Fri Dec 06, 2019 5:30 am
The domain was registered last year 2018.
