Error publishing in WB 15.1
longman
Post by longman » Tue Oct 15, 2019 8:31 am
Hi pablo,
i just got WB 15.1, I get this error when publishing my site:
Details:
The server returned extended information
200 TYPE is now 8-bit binary
425 Unable to identify the local data socket: Address already in use
500 I won't open a connection to 10.8.0.9 (only to 45.9.249.76)
500 Unknown command
Closing FTP connection...
Removing temporary files...
Publish failed!
*** END OF PUBLISH ***
How to solve this?
Ty
Re: Error publishing in WB 15.1
Post by Pablo » Tue Oct 15, 2019 9:03 am
Did it previously work?
If yes, then maybe there is a problem on the host side?
Or maybe your firewall blocks the connection?
Related FAQ:
http://www.wysiwygwebbuilder.com/forum/ ... 10&t=36493
longman
Post by longman » Tue Oct 15, 2019 10:43 am
It worked in version 14.
My error number is 12003, its not in FAQ section.
longman
Post by longman » Tue Oct 15, 2019 10:48 am
my firewall is off.
It keeps uploading and around 50% it suddenly fails...
Post by Pablo » Tue Oct 15, 2019 11:24 am
Did you use the same settings in WB14?
Does it work when you switch to 'winsock'?
Note that the error normally indicates a firewall or router related issue:
longman
Post by longman » Tue Oct 15, 2019 12:37 pm
I been all day trying to publish, it fails every time :(
I tried to Reset the network in my windows, it did not help.
Firewall is and always been off in my windows.
As for router, I do not know what to do, should I bring a network specialist or someone?
longman
Post by longman » Tue Oct 15, 2019 1:47 pm
I can Test and Explore the FTP in publish window, all are ok.
But when it comes to publishing, it publishes like 30-40% and suddenly fails.
It happens every single time, so weird
Post by Pablo » Tue Oct 15, 2019 2:34 pm
Did you try with 'winsock' selected?
What is the error in that case?
