Why are codepage changed when publishing?
michael@ojabiler.dk
Post by michael@ojabiler.dk » Mon Nov 05, 2018 10:08 am
Hi experts,
I am using WB12!!
In page properties i have changed the character set to UTF-8 from iso-8859-1
The published page still have <meta charset="iso-8859-1"> in the header
What am i missing?
Thanks in advance
Michael from Denmark
Re: Why are codepage changed when publishing?
Post by BaconFries » Mon Nov 05, 2018 10:26 am
You are most likely viewing a cached version of the page. Please clear your browser cache by pressing F5 on your keyboard and review.
michael@ojabiler.dk
Post by michael@ojabiler.dk » Mon Nov 05, 2018 11:37 am
Hi Baconfries and thanks for your reply!
My problem has nothing to do with cache - if i change an H1 tag i ca see it in the published file
but the character set i type in the page properties are some how overwritten when publishing !!
Post by Pablo » Mon Nov 05, 2018 12:33 pm
Can you share your project file so we can see what you have done?
michael@ojabiler.dk
Post by michael@ojabiler.dk » Mon Nov 05, 2018 12:56 pm
Hi pablo,
one of the pages are https://leasebil.nu/default.asp
Please the properties here https://leasebil.nu/test/screenshot-page-properties.png
Thanks in advance
Post by Pablo » Mon Nov 05, 2018 1:16 pm
Did you also change the master page?
michael@ojabiler.dk
Post by michael@ojabiler.dk » Mon Nov 05, 2018 1:41 pm
Hi Pablo,
Thank you for your very quick response.
No i have not changed the masterpage and it makes sense if this is the reason. I will try it and get back.
Pablo we are facing problems with the codepages because of the danish letters!
If i choose the iso character set in the properties, all fields are showing correct on the page including the danish characters
but seo characters as arrows ect. are not working?
If i choose the utf-8 - its oppesite - but if i manually open each page in notepad and save the pages both works - but it's a
major time issue. Do you know of any solution?
Best regards Michael
michael@ojabiler.dk
Post by michael@ojabiler.dk » Mon Nov 05, 2018 1:55 pm
Hi Pablo,
By changing the masterpage the tag gets correct after publishing :-)
But if you take a look on the page below, the danish characters are not showing right :-(
https://leasebil.nu/privatleasing/audi/ ... nium-5d-95
Hope you can help me with a solution so titles are correct for seo and descriptions including danish characters are also
Thank You in advance
Post by Pablo » Mon Nov 05, 2018 2:20 pm
Does it look correct in local preview?
If yes, then it may be related to server configuration.
michael@ojabiler.dk
Post by michael@ojabiler.dk » Mon Nov 05, 2018 9:33 pm
Hi Pablo,
Thank you for your always fast reply :-)
After finding out the solution i have decided to make two master pages:
- one for the pages which need seo tricks
- one for the pages which shows information with the danish characters
Not a clean solution but it seems to work :-)
In a small country as Denmark we are used to be a minority - i can live with my choice :-)
WYSIWYG is a fantastic development tool wit an amazing support - thank you
Best regards from Denmark
Michael
Bluesman
Post by Bluesman » Sun Nov 18, 2018 7:51 pm
Hi Pablo,
Michael
Hi Michael, I'm using the UTF-8 with swedish sites and have no issues with characters. I think Sweden and Denmark has the same part of the fonts :D
"Make My Day"
See my Website
