Upload
kenmed
Upload
Post by kenmed » Fri Oct 12, 2018 2:08 pm
Hi
This page used to work well but the host has changed to Windows and after that I can´t publish this file. I have spoken with the host, we have gone through the settings together but it does not work. I have 4 other pages and they work fine. They are not on windowsplatform. I have tried to take away the old page and just made some text and a picture to upload but the old page is still there. Tried in tools winnet and winsock but no luck. Cleard cache several times. Any clues?
Ken
*** START OF PUBLISH ***
Scanning publish folder...
Found 4 file(s).
Initializing FTP connection...
Checking host...
Host was successfully parsed.
Connecting to xn--bjrks-pra0j.se...
Using PASV mode.
Succesfully connected.
Current directory is '/s006568a'
Status: 550 Access is denied.
Uploading 'björkås.css'...
Internet Exception Error 12003
Details:
Servern returnerade ytterligare information
200 Type set to I.
227 Entering Passive Mode (81,95,105,73,207,167).
Closing FTP connection...
Removing temporary files...
Publish failed!
*** END OF PUBLISH *
Re: Upload
Post by Pablo » Fri Oct 12, 2018 2:43 pm
Are you sure that you are publishing to the correct folder on the server?
Maybe the filename is not supported by the server?
Related FAQ:
https://www.wysiwygwebbuilder.com/forum ... f=10&t=131
kenmed
Re: Upload
Post by kenmed » Fri Oct 12, 2018 2:58 pm
I seems like this file is hiding somewhere?I have not used another filename. Only index.wbs.
Ken
Re: Upload
Post by Pablo » Fri Oct 12, 2018 3:10 pm
Maybe it is the name of your project?
kenmed
Re: Upload
Post by kenmed » Fri Oct 12, 2018 4:09 pm
I made a new page saved as bjorkas.se saved in webbuilder as the other pages but no luck. This message björkås.css is in the log but I can´t find this. Tried changing every setting but no luck so far. The page is not found is the latest respond! But the FTP says published?
Ken
Re: Upload
Post by Pablo » Fri Oct 12, 2018 5:12 pm
Maybe your Windows temporary folder is read-only or corrupt?
kenmed
Re: Upload
Post by kenmed » Fri Oct 12, 2018 5:18 pm
Don´t know how to find that out. Any clues? Or I talk to the support and change back to another platform, unix autobahn?
Ken
Re: Upload
Post by Pablo » Fri Oct 12, 2018 5:34 pm
I meant the temporary folder on your own computer.
If you are not an advanced user then you can use Disk Cleanup, to empty the temporary folder.
kenmed
Re: Upload
Post by kenmed » Fri Oct 12, 2018 5:54 pm
I talked to the host and changed back to previous set. hopefully that will do. Otherwise I be back tomorrow :D
Ken
kenmed
Re: Upload
Post by kenmed » Sat Oct 13, 2018 12:12 pm
So I changed back from the new platform, windows, to the old one and it worked directly.
Ken
