Strange text in top of browser.
Pierre Van Hoof
Post by Pierre Van Hoof » Mon Sep 17, 2018 11:44 am
I create a blanco new project.
I use the predefined "contactForm" from the forms.
Left you have a google map right you have "Mail us" (the 6° form)
This is the only thing you find on that page.
When I press F5 within Web builder (updated with last version)
The form is show perfectly.
When I publish the form on my PC en start using "index" a disturbing message is displayed on top of the browser.
What I'm I doing wrong??
This is the displayed message:
"; } if (!empty($error)) { $errorcode = file_get_contents($error_url); $replace = "##error##"; $errorcode = str_replace($replace, $error, $errorcode); echo $errorcode; exit; } $internalfields = array ("submit", "reset", "send", "filesize", "formid", "captcha_code", "recaptcha_challenge_field", "recaptcha_response_field", "g-recaptcha-response"); $message .= $eol; $message .= "IP Address : "; $message .= $_SERVER['REMOTE_ADDR']; $message .= $eol; $logdata = ''; foreach ($_POST as $key => $value) { if (!in_array(strtolower($key), $internalfields)) { if (!is_array($value)) { $message .= ucwords(str_replace("_", " ", $key)) . " : " . $value . $eol; } else { $message .= ucwords(str_replace("_", " ", $key)) . " : " . implode(",", $value) . $eol; } } } $body = 'This is a multi-part message in MIME format.'.$eol.$eol; $body .= '--'.$boundary.$eol; $body .= 'Content-Type: text/plain; charset=ISO-8859-1'.$eol; $body .= 'Content-Transfer-Encoding: 8bit'.$eol; $body .= $eol.stripslashes($message).$eol; if (!empty($_FILES)) { foreach ($_FILES as $key => $value) { if ($_FILES[$key]['error'] == 0) { $body .= '--'.$boundary.$eol; $body .= 'Content-Type: '.$_FILES[$key]['type'].'; name='.$_FILES[$key]['name'].$eol; $body .= 'Content-Transfer-Encoding: base64'.$eol; $body .= 'Content-Disposition: attachment; filename='.$_FILES[$key]['name'].$eol; $body .= $eol.chunk_split(base64_encode(file_get_contents($_FILES[$key]['tmp_name']))).$eol; } } } $body .= '--'.$boundary.'--'.$eol; if ($mailto != '') { mail($mailto, $subject, $body, $header); } header('Location: '.$success_url); exit; } ?>
Re: Strange text in top of browser.
Post by Pablo » Mon Sep 17, 2018 12:10 pm
This is the code of the form processor.
- make sure the page extension is set to PHP
- make sure the server supports PHP
Related FAQ:
https://www.wysiwygwebbuilder.com/forum ... 10&t=32967
Post by BaconFries » Mon Sep 17, 2018 12:11 pm
This is not strange text this indicates that you are using a 'Form' as this uses php then the page extension should be set to .php rather than .html
Also note for reference you cannot 'Preview' php locally you will first need to publish to your host/server to see the results.
Pierre Van Hoof
Post by Pierre Van Hoof » Mon Sep 17, 2018 12:49 pm
That simple :-)
Thanks for the help
