Site is messed up on Mac Safari - why and how to solve?
longman
Post by longman » Fri Aug 17, 2018 5:01 pm
Hi guys,
I checked my site on Safari on mac and it's all messed up, i wonder why? in Windows, chrome firefox and others are all fine, but in mac Safari the flex boxes and all are messed up :(
Awaiting your help.
WWBman
Re: Site is messed up on Mac Safari - why and how to solve?
Post by WWBman » Fri Aug 17, 2018 5:11 pm
The web address would be useful. :wink:
longman
Post by longman » Fri Aug 17, 2018 5:17 pm
I wish i could send you my address via private message. any other way i send you?
Post by Pablo » Fri Aug 17, 2018 5:29 pm
Is your Mac up-to-date?
Older browsers do not support flexbox.
Also note that valid names of objects and files are very important. Invalid names may work on Windows but not on other platforms, because there are stricter rules on other platforms.
See also:
https://www.wysiwygwebbuilder.com/forum ... f=10&t=131
https://www.wysiwygwebbuilder.com/forum ... 10&t=64868
Tip: if you run into a problem then reduce the page with a minimal number of objects to see if that works. Then re-add objects one by one until you have found the problem.
longman
Post by longman » Fri Aug 17, 2018 6:18 pm
Hello Pablo,
I followed and applied your Naming advice on a page as test, then i switched to Macbook and opened that page live and the flexes are all still messed up.
I sent you the link of my site page to your email, hopefully you can take a look and let me know what is wrong?
Thanks!
longman
Post by longman » Fri Aug 17, 2018 6:19 pm
The thing is, everything look messy, the Margins (spaces), the menu, everything.
Post by Pablo » Fri Aug 17, 2018 8:32 pm
I have visited the web page on my mac but do not see any issues. it looks exactly the same for me as in Windows.
Maybe there is an issue with your browser?
For example, maybe you have installed an ad blocker which modifies the HTML code in the browser?
Note:
the code you have added to the end of the page is not correct. There should not be any code outside the <html> tags. This is 'fatal' error.
longman
Post by longman » Sat Aug 18, 2018 3:47 am
Thanks for checking Pablo,
The html i added at the end of the page, is statcounter.com code, it must be at the end of the page in order to show statistic of visitors. if not choosing "End of page" in html properties, where do you suggest me to choose for it?
I'll look into safari issue, maybe its my man issue
Post by crispy68 » Sat Aug 18, 2018 3:52 am
The statcounter code is to be placed before the end <body> tag and not end of the page.
longman
Post by longman » Sat Aug 18, 2018 3:55 am
right, i re read statcounter installation, indeed it says inside the closing "body" tag - </body>
Thanks Crispy68!
