Preview problems mobile
Paul Wrigley
Post by Paul Wrigley » Fri Mar 09, 2018 10:16 am
When previewing @320px and 480px some of the writing from the 3rd paragraph is showing at the top of the page as well as were it should be.
Re: Preview problems mobile
Post by Pablo » Fri Mar 09, 2018 10:45 am
What is the URL of the page so I can see what you have done?
I also may need your project file to be able to help you.
Paul Wrigley
Post by Paul Wrigley » Fri Mar 09, 2018 10:59 am
Hi Pablo,
Site not published yet, I have attached a link below.
http://www.mediafire.com/file/q3ge5235r ... 29_Ltd.wbs
Regards Paul
Post by Pablo » Fri Mar 09, 2018 11:02 am
Where in your project do I need to look to see the problem?
Paul Wrigley
Post by Paul Wrigley » Fri Mar 09, 2018 11:09 am
The problem is on the 'About Us' page in the heading/title section, there is part of the 3rd paragraph showing behind the motif and Abbey Services heading.
If you need to see it I will have to try and send another link as the first link I sent you only shows the index (home) page.
Regards
Paul
Paul Wrigley
Post by Paul Wrigley » Fri Mar 09, 2018 11:26 am
Hi Pablo,
I have attached a new link so you can select 'About Us' tab and see the problem in preview @ 320px and 480px.
Regards
Paul
Post by Pablo » Fri Mar 09, 2018 11:29 am
In the default view unhide object 'Abbey_small_Text', then drag the object to an empty part of the page. Now hide the object again and republish.
Paul Wrigley
Post by Paul Wrigley » Fri Mar 09, 2018 11:51 am
Hi Pablo,
The problem is solved, could you tell me why it happened so as not to make the same mistake in the future.
Thank you very much
Paul
Post by Pablo » Fri Mar 09, 2018 12:15 pm
If you merge objects then they will be merged into one image with the page background. And because the text object was covered with text, this was included in the merged image.
Note that merged objects are not responsive. So they will only 'look good' on the default view.
Paul Wrigley
Post by Paul Wrigley » Fri Mar 09, 2018 5:52 pm
Thanks Pablo,
Regards
Paul
