eBook publishing
http://www.wysiwygwebbuilder.com/publish.html
http://www.wysiwygwebbuilder.com/preview.html
Frequently Asked Questions about Publishing
eBook publishing
As some ebook formats are just HTML under the covers, is there any possibility that WYSIWYG Web Builder may be able to publish to these formats in the future?
Re: eBook publishing
You can add external HTML files via the Site Manager or by adding them via a File Publisher object.
Note however that WWB is not a HTML or code editor so you cannot edit these files.
I wasn't talking about editing the HTML files in WYSIWYG WB, but publishing mobi or epub files from the WYSIWYG WB project as a 'Publish' option.
i.e. Writing your ebook in WYSIWYG WB and using it as a mobi/epub generator.
I imagine this would take a fair bit of work to do and you may possibly deem it to be outside the remit of the application.
I'm sorry the ebook format is not supported. The software was designed to generate standard HTML files only.
