Problem Generating Html output more than 300 pages
userwys
Post by userwys » Mon Nov 20, 2017 12:10 pm
Hello
I have more than 300 pages. Every one with the same master frame. So if I change the master frame when I publish entire web site / publish files or modified objets only the programs gives a error from windows (wysiwyg stopped working. Windows will close the program...) This error is when the program is generating html output.
I'm going to create more pages, but I need to publish all the pages at the same time. How can I do?
(I increase the connection timeout to 120 seconds) (Menu->Tools->Options->Publish)
Re: Problem Generating Html output more than 300 pages
Post by Pablo » Mon Nov 20, 2017 1:17 pm
This is indicates that the project is too big to fit into memory (max 2GB, because it's a 32bit application).
In that case there is no other way then to publish selected pages only or reduce the size of your project's content (use smaller images).
Alternatively you can try the 64bit version, which support larger projects (but no extensions yet!)
https://www.wysiwygwebbuilder.com/forum ... =1&t=77283
userwys
Post by userwys » Mon Nov 20, 2017 1:26 pm
My version is 11 not 12. Can I update?
Post by Pablo » Mon Nov 20, 2017 1:34 pm
Version 12 is an upgrade.
For more information about the upgrade please read this:
http://www.wysiwygwebbuilder.com/howtoupgrade.html
userwys
Post by userwys » Tue Nov 21, 2017 1:54 pm
I bought yesterday the new update and used the 64 bit version. And I have the same problem. I bought it because you tell me that the program supports larger proyects. But it doesn't. I have more than 300 pages but I need to create more pages...
Post by Pablo » Tue Nov 21, 2017 2:17 pm
Didn't you try it first, before you bought it?
Note that the 64 bits version is still in beta.
Did you check the memory usage of your project?
Related FAQ:
https://www.wysiwygwebbuilder.com/forum ... 10&t=35772
Post by crispy68 » Tue Nov 21, 2017 7:04 pm
Hi userwys,
I'm curious at what type of site you have with over 300 pages? Do you have a link to your site?
