Sitemap
Garfield
Sitemap
Post by Garfield » Wed Oct 18, 2017 7:52 am
Hi Pablo
I need your help... When I'm publishing the webpage on the server including SiteMap, there is no sitemap.xml on the server.
a few weeks ago I created and transferred another website and including SiteMap, and the SiteMap is on the server. What can it be? it has always worked so far.
create sitemap is activ/ URL ist correct with http://www.internet-am-hochrhein.de / do not include this page in sitemap is only active for a few sites.
Thanks for your help
Re: Sitemap
Post by Pablo » Wed Oct 18, 2017 8:07 am
Did you publish the entire website?
If you publish a single page then the sitemap will not be generated.
Garfield
Re: Sitemap
Post by Garfield » Wed Oct 18, 2017 8:11 am
Yes I published the entire Website multiple times
Re: Sitemap
Post by Pablo » Wed Oct 18, 2017 8:38 am
Do you see the file in the publish log?
Garfield
Re: Sitemap
Post by Garfield » Wed Oct 18, 2017 9:00 am
Thanks a lot for your help. The problem was, that it reset the publishing settings to the old publishing path ... and there I found the xml file. I transfered it to the new publishing path, xml file is there. Evereything is o.k. now. I am so Sorry, it was my mistake. WWB and Pablo are great and thank you!
