show image depending on android or iphone
kenderuiter
Post by kenderuiter » Mon Jan 06, 2020 9:28 pm
On my mobile site I want to be able to show an image with a link to the facebook app.
Because I understood that adroid needs another kind of link than the iphone operating system, I want to be able to show an image depending on the os the website is running on
So I place two images on my site (one for android and one for iphone)
Depending on the operating system the 'android link image' shoud only be shown on the android os and the iphone image should only be shown on the iphone os.
Can I do that using WWB? (I am using version 14)
Re: show image depending on android or iphone
Post by Pablo » Tue Jan 07, 2020 7:26 am
I doubt that you will need two separate links for Facebook.
I think you can use the same link.
Implementing a conditional link requires scripting.
kenderuiter
Post by kenderuiter » Tue Jan 07, 2020 7:43 am
Hello Pablo,
thank you for your reply!
a link to facebook.com can be done with one link
on a mobile device however i want to navigate the link to the facebook app (so not to a browser)
any ideas as to jow i can do that?
regards,
Ken
Post by Pablo » Tue Jan 07, 2020 8:49 am
If you use breakpoints then you can show different objects for different screen sizes.
If you want to activate a link for a specific device then you will need to implement a script.
Post by zinc » Tue Jan 07, 2020 10:09 am
This might help you...
https://www.wysiwygwebbuilder.com/forum ... 53&t=78206
Good news everyone!
