themeable button width changes - bug?
longman
Post by longman » Tue Jun 19, 2018 4:52 am
I have this themeable button that has Link to an external web address, the link has character = inside the url (its an affiliate link and must have =), but when i use that link, the width of the button will change to its text size.
I have attached example - two buttons, one has URL with = and the other has URL without = inside. When you preview you will see what happens.
WB file https://expirebox.com/download/1bc6cb03 ... e25c5.html
Another point, this only happens if i have other breakpoints active.
I believe this is a bug? can it be solved?
Thanks!
Re: themeable button width changes - bug?
Post by Pablo » Tue Jun 19, 2018 6:25 am
Thanks for the information,
The problem is actually related to the use of 'gid=' in the link. This is internally used to relocate the inline styles.
I will implement a workaround for this in the next update.
longman
Post by longman » Tue Jun 19, 2018 7:40 am
Big Thanks!!
