Menus change
ncveggm
Menus change
Post by ncveggm » Sun Dec 03, 2017 10:27 pm
Hi dear
I have different folders in site each one related to group of pages with the same menu.
So i have a different menus for each group of pages
I put all menus in master page. How i can show and hide each menu with it's related group of pages
NB. All pages setting master page properties for the master page which contain all menus
Re: Menus change
Post by Pablo » Mon Dec 04, 2017 6:54 am
You can have multiple master pages. So for each group you can use a different master page.
ncveggm
Re: Menus change
Post by ncveggm » Mon Dec 04, 2017 12:49 pm
I need to call the menu from the same master page
Re: Menus change
Post by Pablo » Mon Dec 04, 2017 2:05 pm
That will only be possible via custom scripting, this cannot be done visually.
ncveggm
Re: Menus change
Post by ncveggm » Mon Dec 04, 2017 7:11 pm
may you give me you opinion how the two navigation bars in the following address are fixed ( https://hannainst.com/testers) I need to do two navigation menus fixed but one change the content with the change of page groups ( the ray one)
thanks
Re: Menus change
Post by Pablo » Mon Dec 04, 2017 7:15 pm
You can place two separate menu on a (fixed) page header.
If you need different menus for different pages then either create multiple master pages or create a unique header for each page.
