Need some advice and help.. (SORTED)
MartinPorter
Post by MartinPorter » Fri Oct 06, 2017 11:16 am
Hi everyone.
I have a vertical menu on the left hand side (using ShinyButton extension) maybe not the right one to use but
has anyone find a way to move the menu buttons while the user scrolls up and down the page so they are always
available to the user?
thanks for any help you can give me!
Regards
Martin...
Have worked it out myself but thanks for everyone for reading!
Re: Need some advice and help.. (SORTED)
Post by Pablo » Fri Oct 06, 2017 1:03 pm
You can do this by using a sticky layer.
http://www.wysiwygwebbuilder.com/morelayers.html
