Navigation Bar goes behind grid layout
Andrew Swinfield
Post by Andrew Swinfield » Fri Sep 01, 2017 7:22 am
ok 2 pages one master with just a flexbox at top of page with a css menu in it page 2 index with a grid layout at top with a jquery tab in one cell when preview the menu goes behind the grid layout i have tried move forward but not working can some one help thank :D
Re: Navigation Bar goes behind grid layout
Post by Pablo » Fri Sep 01, 2017 7:39 am
Please share your project so I can see what you have done.
Note that menus are usually part of a page header, which you can set to 'in font of content'.
Layout grids do not have a z-order. They are rendered in the order they are on the page.
Andrew Swinfield
Post by Andrew Swinfield » Fri Sep 01, 2017 7:59 am
Thank you for your quick reply the website I'm building is fully responsive with no breakpoints I have looked at using the page header but I am unable to make the page header do what i require here is a link
on the index page you will see the menu is hiding but on the wedding and courses the menu is in front I look forward to hearing from you
Last edited by Andrew Swinfield on Fri Sep 01, 2017 9:01 am, edited 1 time in total.
Post by Pablo » Fri Sep 01, 2017 8:24 am
In that case the only way you can change this behavior is by adding the following code
<style>
#wb_masterCssMenu1
   z-index: 9999 !important;
</style>
One again, please note that there is no z-order when objects are floating. The next object will always be on top of the previous one. Arrange will only change the order of the objects on the page.
Andrew Swinfield
Post by Andrew Swinfield » Fri Sep 01, 2017 9:00 am
Thank you it works good :D
