new transfers and tour site
You can use this section of the forum to show your website created with WYSIWYG Web Builder to other users.
gano101
Post by gano101 » Sun Sep 16, 2018 11:26 pm
Hi folks
A new site I made went live the other day, I'm still working out a few issues with it.
I'd really appreciate if you could take a look and make some suggestions on what could be added or changed. Feel free to be as critical as possible (I wont take it personally)
http://largsplatinum.com
thanks in advance
gano101
Re: new transfers and tour site
Post by gano101 » Sat Oct 06, 2018 5:02 pm
**mobile help**
okay, so I'm kinda new to mobile sites, but I've updated the one for this site http://largsplatinum.com/ I've used the overlay menu but I can't get it to display in colour, it's always monochrome... am I doing something wrong?
thanks in advance
GrahamW
Post by GrahamW » Sun Oct 07, 2018 7:36 am
hi Gano101
how did you get the zoom effect on the carousel
Graham
gano101
Post by gano101 » Sun Oct 07, 2018 3:36 pm
Insert this between header tags
<style>
@-webkit-keyframes background-zoom
0% { -webkit-transform: scale(1.0) }
100% { -webkit-transform: scale(1.2) }
@-moz-keyframes background-zoom
0% { -moz-transform: scale(1.0) }
100% { -moz-transform: scale(1.2) }
@keyframes background-zoom
0% { transform: scale(1.0) }
100% { transform: scale(1.2) }
</style>
<script>
function backgroundZoom(id, frame)
var backgroundProps = ["background-image", "background-position", "background-repeat", "background-size"];
var props = $('#' + id + ' .' + frame).css(backgroundProps);
$('#background-zoom').remove();
var $obj = $('<div id="background-zoom" style="width:100%;height:110%"></div>');
$obj.css(props);
$('#' + id + ' .' + frame).prepend($obj);
AnimateCss('background-zoom', 'background-zoom', 0, 10000);
</script>
GrahamW
Post by GrahamW » Mon Oct 08, 2018 3:02 am
thanks gano101,
i tried that and it does not work. I am using the standard built in carousel.
I just clicked on page HTML and then between head tags added the code you posted is that correct
Graham
robertrz
Post by robertrz » Wed Oct 10, 2018 5:48 pm
I really like your site, its amazing.
But I have something to tell you, sometimes its difficult to see you menu, like the image:
Sorry for my bad english.
gano101
Post by gano101 » Thu Oct 11, 2018 1:47 pm
Hi Robertrz,
Thanks for the feedback, I do agree the transparent image with the changing background does make it difficult to see sometimes... and i thought about that, but I think the effect is worth the downside. I may change it in the future, who knows :)
thanks again
jerryco
Post by jerryco » Thu Oct 11, 2018 5:02 pm
Hi, the site has a nice vibe! Consider using a domain email address as this gmail.com looks a little amateur to me.
pajadt
Post by pajadt » Thu Oct 11, 2018 6:42 pm
Hi
I see here in my browser empty space from right size when scroll browser/ left - right /, that must fixed, maybe some html is object/ scripts / is out page, so put him inside. and problem be solved
- Second what i not like is to much different color, orange gray , violet , blue etc...
advice - Try to find best combination for Header, black is not so good solutions, in this design.
Anyway, that is advice, also gold logo not is perfect soltions when have carosel and always is other color in background, sometimes is good backgroud sometimes not - not visible logo.
About Design, Design is very good.
gano101
Post by gano101 » Thu Oct 25, 2018 5:28 pm
true, I offered a domain email to the client, he prefers to go with google. I guess the customer is always right :wink:
gano101
Post by gano101 » Thu Oct 25, 2018 5:33 pm
Hi
Hi mate
good feedback, I believe I fixed the left/right scroll, it was a hidden layer :)
on the colours, black and gold etc, this was the only thing that the client didn't want to budge on, I believe he's using similar style on his vehicles and wanted it to translate to the website. While I agree with you and it may look good on a static object (like a car) it may not be the perfect solution on a website. I have feed your comments back and the client may decide to change it.
thanks again for taking the time to comment tho, much appreciated.
GrahamW
Post by GrahamW » Sun Oct 28, 2018 5:47 am
Hi Gano101
with the carousel zoom I used the code you gave in an earlier reply but it does nothing, is there anything else you need to do. I assume you have used the standard WB carousel as well
Graham
gano101
Post by gano101 » Mon Nov 12, 2018 7:33 pm
Hi Gano101
Graham
sorry, my bad
You've got to add one of these events for each frame :)
GrahamW
Post by GrahamW » Mon Nov 12, 2018 8:35 pm
Hi gano101
I can't see the image you posted
Bart Design
Post by Bart Design » Mon Dec 03, 2018 12:04 pm
Hi Gano 101, i also like the zoom, (not crazy about Java scripts do.) Is it also possible to do this with a parallax image? And do i still need your code or do i just can use events?
