First time using layout grid-need some feedback
You can use this section of the forum to show your website created with WYSIWYG Web Builder to other users.
hobo
Post by hobo » Sat Mar 03, 2018 4:26 pm
Just like to say there are many good people here in the forum that are very helpful.
So check out my first layout grid site.
Any suggestions/critizisem welcome.
:oops:
www.angustoolrental.com
electrochrisso
Re: First time using layout grid-need some feedback
Post by electrochrisso » Sun Mar 04, 2018 10:16 am
Not bad, seems to work ok and easy to navigate, a bit plain though. :)
alexmasss
Post by alexmasss » Sun Mar 04, 2018 5:19 pm
Looks good but on smartphone if i swipe with the finger there is blank space at the right. It should not be there.
Post by BaconFries » Sun Mar 04, 2018 5:29 pm
@alexmasss works fine on mine...no white space in either portrait or landscape. With this said it most likely due to your phone screen size smaller than the breakpoints used maybe say 320px? we're the lowest here is 480px so this will explain the scroll. Most phones now use a larger resolution over 320px.
hobo
Post by hobo » Sun Mar 04, 2018 8:26 pm
Thanks for your coments.
I use default size 1250 and BP are 1024, 768 and 320 maybe I should add 480 as well.
Still learning :-)
pajadt
Post by pajadt » Tue Mar 06, 2018 11:00 pm
Play with google fonts, color, also this slideshow try to be smaller than now better visual effect, other is mostly ok
mayur007
Post by mayur007 » Fri Mar 09, 2018 10:03 am
remove the image with finger change it with proper image, that doesn't look pro
hobo
Post by hobo » Sun Mar 11, 2018 11:31 am
Thanks everyone for feedback.
Yes image with finger I should have cropped? I will go take new different photos and redo.
Also google fonts I have to get to know how to.
bubblegumweb
Post by bubblegumweb » Mon May 28, 2018 10:35 pm
I agree about sections being plain. When the website opens the header and the slider look great, then as you scroll down the layout becomes a little plain. Apart from that, nice website. Well done
Regards
Gary
