WYSIWYG Web Builder 15.0.6 update
*** Current version: WYSIWYG Web Builder 15.3.0 ***
Post by Pablo » Fri Aug 16, 2019 10:08 am
WYSIWYG Web Builder 15.0.6 fixes known problems and includes other improvements.
What's new?
- Fixed: Switched 'disable' and 'enable' labels in events.
- Fixed: Texture background not saved for Banner.
- Fixed: Go Menu does not render initial text in workspace.
- Fixed: Border image uses wrong size.
- Improved: Border width calculations for floating images.
- Improved: Catch possible conflicts with pipe-characters in Unsplash text.
- Improved: Redesigned link implementation for in <p> output format (better support for Unicode and style filter).
How to update from previous 15.x versions?
2. If you already have version 15.x you can install it in the same location as the previous version.
32bit: http://www.wysiwygwebbuilder.com/wb15update.zip
64bit: http://www.wysiwygwebbuilder.com/wb15x64update.zip
