WYSIWYG Web Builder 5.0 released!
*** Now available: WYSIWYG Web Builder 14.2 ***
Post by Pablo » Sun Dec 09, 2007 8:28 am
After months of hard work, it's finally here: WYSIWYG Web Builder 5.0.
More than 50 new features! The most powerful web builder we've ever created.
- Improved: Resize and rotate handles.
- Improved: Shadow offset does no longer affect the shape size.
- Improved: Shadows are rendered outside shape (like in MS products).
- Improved: Resizing rotated object now remains in the same place and does no longer increase opposite side.
- Improved: Added more events (OnKeyDown, onKeyPress, onKeyUp, OnReset, OnMouseMove etc)
- Improved: Characterset options
- Improved: Redesigned HyperLink style window.
- Improved: Navigationbar styles load faster.
- Improved: Web Builder now outputs jpg (instead of png) when possible. This results in smaller/faster pages.
- Improved: PayPal images have been updated to match the new PayPal style.
- Improved: New default navigationbar button design
- New feature: Added 7 Ready-to-use-javascripts: 'Bookmark this page', 'Browser detection', 'Fade in background', 'Random background color', 'Screen resolution', 'Swirling cursor trail' and 'Time greeting'.
- New feature: Renamed 'Ad Rotator' to 'Slide Show' and added the ablity to manually navigate images by using events (SlideShow Next and Previous actions).
- New feature: Border style for Shapes.
- New feature: Size and position of the Object HTML window is now saved between sessions.
- New feature: Pattern fill effect for Shapes (anti-alias only)
- New feature: Vista-like Glass effect in Shapes (anti-alias only)
- New feature: New Star Shape with customizable point count and inner radius.
- New feature: Added support for formatted text inside Shape object.
- New feature: Ability to configure names of dynamically generated images.
- New feature: Ability to crop images.
- New feature: Ability to rotate images and shapes through the Quick Properties window (Angle property).
- New feature: Ability to add reflection to images
- New feature: Ability to add shadows to images.
- New feature: Ability to set opacity of images and shapes.
- New feature: Ability to set Hue/Saturation of images
- New feature: Set stencils for images
- New feature: Most image effects can now also be applied to Image Maps.
- New feature: Mosaic effect for images
- New feature: Colorize effect for images
- New feature: Gold/Ice/Metalic effects for images
- New feature: FishEye effect for images
- New feature: Inner Bevel Frame effect for images
- New feature: Soft Edges/Feather effect for images
- New feature: 'Apply to All' option in Page Properties
- New feature: Full screen mode. Quickly switch fullscreen mode using F11!
- New feature: Added the ability to show/hide any object in the Object Manager
- New feature: Added the ability to lock/unlock objects in the Object Manager
- New feature: Import Page from another project (Menu->Page->Import)
- New feature: Ability to publish only changed files.
- New feature: 'Test connection' option in remote publish window.
- New feature: Popup window support for links (with optinal position, size, toolbar, statusbar, scrollbars etc.)
- New feature: Added support for file links, (files will be automatically published!).
- New feature: Smart links; link to the next, previous, parent or child page. Also close, reload or print page options have been added.
- New feature: Favorites icon property for pages.
- New feature: Ruler guides. Ruler guides are placed on the page by dragging them from the rulers or by specifying precise positions using the new 'Format Ruler Guides' dialog box.
- New feature: Snap to guler guides (in Guide settings)
- New feature: The toolbox is now fully customizable.
- New feature: Page weight tool to determine the estimated size and download time of a page.
- New feature: Added <body> events (Page Properties).
- New feature: Added the ability to handle text link events.
- New feature: Marquee now supports formatted text (including links!).
- New feature: Page-Language property (search engines may use this tag to categorize documents by language).
- New feature: Added the ability resize navigationbar buttons horizontally.
- New feature: Microsoft, Yahoo and Google compatible sitemap generator.
- New feature: RSS Feed object with podcast option.
- New feature: Added Tab Menu navigation object
- New feature: Added Slide Menu navigation object
- New feature: Blog with built-in RSS feed option.
- New feature: Form Wizard, creating forms was never so easy! including the option to create a new form based on a template.
plus many minor tweaks and improvements!
Download version 5.0 here:
