WYSIWYG Web Builder 4.3 now available!
*** Now available: WYSIWYG Web Builder 14.2.2 ***
Post by Pablo » Tue Jul 03, 2007 2:40 pm
WYSIWYG Web Builder 4.3 fixes all known problems and adds a few new features:
- Fixed: Internal Link selection no longer resets other dialog contents.
- Fixed: Transparency issue with navigationbar buttons
- Improved: Reflect rename of a master page in the pages using it
- Improved: Removed internal link for PayPal object, because only absolute URLs are valid!
- Improved: Added support for Polish currency to PayPal object.
- Improved: Items can now be rearanged by using drag & drop in Photo Gallery, Combobox, Navigationbar, TextMenu and Ad rotator properties.
- New Feature: Added preview option to all image selection windows.
- New Feature: Context menu with formatting tools when in text edit mode.
- New Feature: Added option to display Web safe fonts only (Tools->Options->Misc->Display websafe fonts only)
- New Feature: Added 'Target' property to PayPal object
- New Feature: Drag & Drop background images to workspace from explorer (hold down the SHIFT key while dragging)
- New Feature: Text box has two new options 'Search in Google' and 'Look Up in Dictionary' (experimental).
- Updated documentation (help and manual)
How to update from previous 4.x versions?
1. Download version 4.3 here:
2. If you already have version 4.x you can install it over your previous version. Make sure you select the same folder!
http://www.wysiwygwebbuilder.com/wb4update.zip
Users browsing this forum: No registered users and 4 guests
