WYSIWYG Web Builder 4.1.1 now available!
*** Now available: WYSIWYG Web Builder 14.1.0 ***
Post by Pablo » Tue Mar 20, 2007 6:39 pm
WYSIWYG Web Builder 4.1.1 fixes all known problems and introduces some new features:
- Fixed: Rectangle shape borders joins are now mitered instead of rounded.
- Fixed: Unique image name problems for extensions.
- Fixed: Site Manager drag & drop error handling.
- Fixed: Navigationbar centered instead of left aligned.
- Fixed: Shape shadow clipping.
- Improved: Increased the speed of loading images in the navigationbar style window.
- Added: Navigationbar support for transparent .gif and alpha channel .png images.
- Added: Gradient path shadow style for shapes for even more beautiful shadow effects!
How to update from previous 4.x versions?
1. Download version 4.1.1 here:
2. If you already have version 4.x you can install it over your previous version. Make sure you select the same folder!
http://www.wysiwygwebbuilder.com/wb4update.zip
Users browsing this forum: No registered users and 7 guests
