AutoViewer, PostcardViewer, SimpleViewer, TiltViewer updated
Post by Pablo » Wed Aug 18, 2010 6:10 pm
New versions of the following extensions are now available:
AutoViewer 2.0, PostcardViewer 2.0, SimpleViewer 2.0 and TiltViewer 2.0.
What's new?
AutoViewer
- Uses most recent version of AutoViewer (1.4)
- Optimized the use of GDI resources.
- Added 'Display the "Open Image in New Window..." right-click menu option.'
- Added the ability to configure gallery data filename (useful if you are using multiple galleries in a website).
- Added support for the Pro version.
- Now uses the publish target folder locations for images (WYSIWYG Web Builder 7 feature)
PostcardViewer
- Uses most recent version of PostcardViewer (1.2)
- Added text and frame color properties.
SimpleViewer
- Uses most recent version of SimpleViewer (2.0.3)
- Added 'Display the "Open Image in New Window..." button right-click menu option.'
- Added 'Display the "Go Fullscreen" button and right-click menu option.'
- Added Gallery styles 'Classic', 'Compact' and "Modern'
- Added support for Flickr images.
TiltViewer
- Uses most recent version of Tilt Viewer (1.3.1)
You can download the new versions through the Extension Manager (Menu->Tools->Extension Manager->Available).
These new versions only work in WYSIWYG Web Builder 7.1 or newer.
