WYSIWYG Web Builder 4.05 released!
*** The current version is: WYSIWYG Web Builder 20.2.2 ***
Version 4.05 fixes all known problems and introduces many other minor improvements:
- Fixed: Grid spacing set to zero made drawing extremely slow.
- Fixed: Removing colom in combination with split cell crashes application.
- Fixed: Delete key now works inside Quick Properties window.
- Fixed: Background color of Layers could not be set.
- Fixed: Sub pages of pages within a folder will now also be folder to the folder of the parent.
- Fixed: ESC key in edit mode did not correctly
- Fixed: Bottom and Right attributes of layers now also work in centered pages.
- Fixed: Cell HTML was not copied during page cloning.
- Improved: Implemented exception handler to catch potentional bugs.
- Improved: Stack trace will be saved to 'crash.txt' if an exception occurs.
- Improved: An attempt to save the document will be made before the application closes after an exception.
- Improved: Photo gallery now displays the title below the image.
- Improved: Header code of nested master pages is now also generated.
- Improved: Photo gallery, Navigationbar, Shapes and Banner now also generate the 'title' attribute for FireFox
- Improved: Quick Properties dropdown list is now sorted.
- Improved: Holding down the CTRL key in 'drag-selection' will not select the underlying object, so layered objects and objects on forms can now also be selected this way.
- Improved: Publish window is now resizable.
- Added: <!-- Description --> in generated code for HTML object.
How to update from previous 4.x versions?
1. Download version 4.05 here:
2. If you already have version 4.x you can install it over your previous version. Make sure you select the same folder!
