WYSIWYG Web Builder 6.0.2 update
*** Now available: WYSIWYG Web Builder 12.4 ***
Post by Pablo » Sat Apr 04, 2009 1:27 pm
This is a maintenance release. WYSIWYG Web Builder 6.0.2 fixes all known problems. This is a recommended update for all users!
- Fixed: Using a form on a master page crashes the application.
- Fixed: SiteTree does not work in folder.
- Fixed: Table cell background issue on FireFox.
- Fixed: Added GDFONTPATH to captcha object, because some web servers need this to find the font.
- Fixed: Margin in menubar splitters.
- Fixed: Replaced 'Internal page' with the name of the page in description fields.
How to update from previous 6.x versions?
1. Download version 6.0.2 here:
2. If you already have version 6.x you can install it over your previous version. Make sure you select the same folder!
Users browsing this forum: No registered users and 4 guests
