WYSIWYG Web Builder 5.5 released
*** Now available: WYSIWYG Web Builder 14.2 ***
Post by Pablo » Sun Jul 06, 2008 4:47 pm
The long awaited major update of WYSIWYG Web Builder is finally available!
This update has so many new features (more than 40!) that we've decided to call it: WYSIWYG Web Builder 5.5
What's new in WYSIWYG Web Builder 5.5?
- Fixed: Invalid HTML for Flash object (codespace -> codepage)
- Fixed: Issues with Advanced Button in FireFox 3
- Fixed: Bug in Bubbles script
- Improved: Generating unique images (during preview/publish) for very large projects is now much faster.
- Improved: Image shadow is now more realistic. The offset can now be zero to create a 'glow' effect. Added 'enable shadow' property.
- Improved: The alpha channel information of the original image will be used to generate the shadow.
- Improved: pngfix.htc file updated for better browser compatibility.
- Improved: Images can now also have a border when effects, shadows or rotation are enabled.
- Improved: Changing the border width no longer changes the image size in the designer.
- Improved: RSS Feed now also supports before, inside and after tag HTML.
- Improved: The software now displays a warning if the DPI settings are not set to 96 DPI.
- Improved: Added confirmation message to 'Apply to All' command to prevent overwriting all properties accidently.
- Improved: Menubar now completely validates on http://validator.w3.org
- Improved: Opacity property added to Shape Properties
- Improved: Added 'Rotate' command to context menu of images and shapes.
- Improved: Rendering of themed form controls uses (much) less system resources.
- Improved: Blog object is now also What-you-see-is-what-you-get (real time HTML rendering)
- Improved: Several improvements for HTML import, for example: Web Builder now also tries to use style sheets for imported text and font size conversions (em, pt, %)
- Improved: Align->Space evenly now uses total width/height of the selected objects to determine the spacing (instead of the grid spacing)
- New feature: Added date property to blog items
- New feature: Added event support to Advanced button
- New feature: Added support for 'allowfullscreen' property in Flash object
- New feature: Added readonly property to EditBox, TextArea
- New feature: Added accesskey property to Button, CheckBox, EditBox, RadioButton, Image Button, FileUpload and TextArea
- New feature: Added title property to Button, CheckBox, EditBox, RadioButton, Image Button, FileUpload and TextArea
- New feature: Added disabled property to Button, CheckBox, EditBox, RadioButton, Image Button, FileUpload and TextArea
- New feature: Added style properties to File Upload
- New feature: Added validation opties to File Upload
- New feature: Added style properties to Push Button
- New feature: Added Alternative text and Title properties to RollOver Image.
- New feature: Added border style to Slide Menu
- New feature: Added cellspacing property to Slide Menu
- New feature: Added 'Disable uppercase folder names' option to Slide Menu
- New feature: Added 'Disable collapse feature' option to Slide Menu folder item
- New feature: Center page horizontally and vertically(!) in Page Properties.
- New feature: Added the ability to create a new category in the 'Save as template' window.
- New feature: Added shadow/blur text effect to banner object.
- New feature: Added reflection effect to banner object.
- New feature: You can now set the style for the main menu item and submenu items seperatly
- New feature: Added option to use border for the menubar (and sub items)
- New feature: Added option to set the opacity (transparancy) for sub menu items of the menubar
- New feature: Added padding properties to menubar for more professional looking menus!
- New feature: Added border color and border size properties to Inline Frame.
- New feature: Added 'Refresh' command to reload all images of the current page.
- New feature: Added the ability to set fade effect for slideshow images.
- New feature: Added Asset Manager to manage the locations of images and other files. This can be useful when moving files to another computer.
- New feature: Built-in PHP form processor to make creating forms even more easier (includes support for file upload, anti-hacking and server sided email validation)!
- New feature: Form processor also supports the built-in PHP form processor.
- New feature: Added 16 new tab menu styles!
See also the 'sneak preview' PDF document:
http://www.wysiwygwebbuilder.com/wb5_5_features.zip
This update is free for all registered users of WYSIWYG Web Builder 5.0.
Download your copy of WYSIWYG Web Builder 5.5 now:
Users browsing this forum: No registered users and 4 guests
